586,392 active members*
3,161 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper stalls and changes direction
    Sep 2012
    41
    Hi I have gotten a problem with the stepper on my Y-axis, it has been running perfectly up until a few days ago when in the middle of a program it seemed like the y-axis was stuck. Took everything apart and checked but couldnt find anything wrong. put it back together again and the stepper still wouldnt move it. With no power on there is no problem turning the stepper by hand and moving the table so nothing is stuck. Uncoupled the stepper from the axis and it runs, hooked it up again and it ran for a little while but you never knew which direction + moved it + one time and then suddenly - the next with no system to it. Sometimes it runs the right direction sometimes the wrong direction and suddenly all stalls and it cant pull the table at all.
    I have tried to switch to the driver for another axis to check if it was a driver problem but still the same.
    Anyone experienced something similar to this? and is there something I can do to fix it other than getting a new stepper?
    I am using this setup.
    KL-6050 Bipolar Stepper Motor Drivers
    KL23H2100-50-4B (3/8” Dual shaft with a flat) 570 oz-in
    KL-600-48 48V/12.5A Power Supply
    C10 Bidirectional Breakout Board
    1695
    Re: Stepper stalls and changes direction
    Look for a loose connection between the stepper and driver.
    Measure the motor coil resistances. If one is open or short circuit, then the motor is bad. Note that the reading will be very low. Most multimeters will have trouble.
    Sep 2012
    41
    Found it, there was a break in the cable, changed it out and now everything is good.
  1. Stepper motor stalls while accelerating
    By abdelaziz.saber in forum Stepper Motors / Drives
    Last Post: 04-11-2014, 11:11 PM
  2. stepper only goes one direction
    By HalfRhoVSquared in forum Stepper Motors / Drives
    Last Post: 08-22-2013, 06:18 PM
  3. easydriver + stepper motor stalls
    By scalance in forum Benchtop Machines
    Last Post: 12-19-2011, 06:34 PM
  4. stepper stalls out
    By edgara in forum DNC Problems and Solutions
    Last Post: 10-12-2010, 05:53 AM
  5. Stepper stalls, resonance, and voltage questions
    By boyvox in forum Stepper Motors / Drives
    Last Post: 08-09-2007, 10:19 PM
