586,728 active members*
3,302 visitors online*
Results 1 to 6 of 6
    May 2017
    5
    Exclamation Inaccurate engraving - non exacly engraving
    Hello
    I have 50w china engraver with RDC6442G-B controller the problem is when im engraving on material is like double engraving or like is drunk (can see on foto)
    I have check all mirors and belt and steel nothing. Do any have any solution what iis wrong?
    this problem is when im engraving on x axes or y axes
    Feb 2017
    23
    Re: Inaccurate engraving - non exacly engraving
    you set wrong reverse interval .
    Feb 2017
    23
    May 2017
    5
    Tank you i will tray
    May 2017
    5
    Hello
    I solved the problem.
    The problem was bad wire conection on co2 tube.
    And thank you for fast reply.
    Denis
    May 2017
    10
    Quote Originally Posted by zeka113 View Post
    Hello
    Denis
    How did you work out that there was a bad wire connection on co2 tube? I have similar issue for not accurate / unclean application for long jobs and trying to fix it!
  1. New to laser engraving - black smoke/dust on the product surface after engraving
    By liujiening in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-08-2016, 04:27 AM
  2. Replies: 1
    Last Post: 09-04-2015, 10:54 AM
  3. Chinese Laser Cutting and Engraving Machine TS-6040 60w - Engraving problem
    By Andriette in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-24-2014, 03:44 PM
  4. PHCAD setting cut after engraving deeper engraving
    By herby08 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-25-2012, 10:18 AM
  5. Distinction between laser engraving between special LGP engraving machine when produ
    By CUTCNC in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-21-2011, 09:46 AM
