586,655 active members*
3,982 visitors online*
    Oct 2011
    27
    removing X axis bearing/handle
    How do I remove the X bearing from the saddle of a mini lathe (7x12)
    I need the slide to move just a tiny bit further out (toward the operator) and the part highlighted in red stops the slide. I figure if I can add a little space between the saddle and that bearing part it will work.
    I found pictures of other mini lathe were that part is screwed in, on mine there are no screws or anything. Wondering it I should just try to pull it out, or maybe it is threaded in ?
    any and all help appreciated...
    Bruno
    Attachment 274628
    Sep 2006
    509
    Re: removing X axis bearing/handle
    The graduated dial should be able to slide off the end of the shaft - it is held on by a friction fit (spring) and gentlepersuasion will make it come off. Behind it you will find 2 socket cap screws (3mm hex) hidden in deep holes.
    Attachment 275136Attachment 275138 Attachment 275140
    Mike
    Oct 2011
    27
    that was it ! The dial was pretty hard to pull out, I had no idea it was supposed to slide off !
    thanks a lot, this stopped me from trying something stupid....
  1. Best way to handle an indexing axis
    By jderou in forum Mach Software (ArtSoft software)
    Last Post: 12-14-2013, 11:19 PM
  2. Removing Z-Axis backlash
    By Anokiernan in forum Taig Mills / Lathes
    Last Post: 12-11-2009, 03:07 AM
  3. X axis handle jogs, but won't move in program
    By WillRitter in forum Haas Mills
    Last Post: 10-25-2009, 06:01 PM
  4. removing nut on x axis
    By Kevin Moore in forum Syil Products
    Last Post: 10-08-2008, 03:35 PM
