586,375 active members*
3,420 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > Boolean Difference not working
    Mar 2015
    Hi everyone. I'm new to Rhino (coming from SolidWorks) and am struggling to build a part. I started with a mesh that i turned into a closed polysurface and want to create a sphere encompassing this polysurface and create a shell whose outer surface is the sphere surface and the inner surface is the polysurface.
    When use boolean difference I get "Objects do not intersect", which i don't understand. The outer surface of the sphere does not intersect the surface, but the sphere should be filled and the polysurface definitely takes up volume inside the sphere.
    If I create a rectangular prism and use boolean difference with that and the polysurface I get "Boolean Difference failed".
    Can someone tell me why this isn't working?
    -Thanks
    Apr 2004
    5740
    Re: Boolean Difference not working
    Unlike Solidworks, which is a solids modeler, Rhino is a surface modeler. Unless the surfaces of your spheres intersect, it won't do a Boolean operation; to Rhino these read as two separate closed surfaces nested inside one another. If you create a tunnel between them, you can split it at each surface, and split the surfaces of the spheres, to get a shell (with a hole in it). But the space between the outer and inner surfaces will still be empty as far as Rhino's concerned.
    Andrew Werby
    Website
    Jan 2007
    1795
    following a kind of logic, you might create 2 half sphere, sutract of each, then unify the two half..
    still hard to imgine the reason to making hollow a sphere this way...
    Jun 2005
    260
    Generally, without conversion, I do not think that you can subtract a mesh from a NURBS object.
    Rhino is a solid modeler, just as SolidWorks is, though because it's NURBS based, the resulting object must be a manifold object. So, object such as hourglass or a tennis ball must have a seam somewhere.
  1. What is the difference between wood working and metal working routers?
    By LaughingJaguar in forum Joes CNC Model 2006
    Last Post: 10-17-2016, 07:29 PM
  2. Boolean Subtract Not working with STL Model
    By bill south in forum BobCad-Cam
    Last Post: 07-15-2011, 09:26 PM
  3. BobCadCam V21 Boolean Difference help
    By TurboKris in forum BobCad-Cam
    Last Post: 04-06-2011, 05:50 PM
  4. Boolean
    By camtd in forum Uncategorised CAD Discussion
    Last Post: 09-22-2008, 12:31 AM
  5. Boolean difference failed
    By chetosmachine in forum Rhino 3D
    Last Post: 06-12-2007, 11:24 PM
