586,390 active members*
2,702 visitors online*
    Jan 2006
    35
    v22 on windows 8
    had version 22 installed on a laptop that is now dead. new computer has windows 8. this is a 64bit system. what do I need to do to get this installed and running? going crazy trying to figure this out.
    Re: v22 on windows 8
    You need a 64bit version of the install package, if V22 had one.
    Presumably it came on the media (if you got media) or if you downloaded was a download option when you downloaded your install. Always download and archive all available install options for any package you license, JIC ;-)
    - Nick
    Jun 2010
    4256
    I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations.
    Why should you?
    Cheers
    Roger
    Dec 2008
    4548
    64 bit os will install and run 32 bit apps. V22 was 32 bit.
    First be sure you have upgraded win 8 to 8.1 (free)
    Then look here:
    Make older programs compatible with this version of Windows - Windows Help
    V22 needed all compat settings like disable desktop composition etc. Also needs run as admin setting.
    Best bet is to use that troubleshooter to actually install the app instead of running it on an already installed app. I can dig up better details about doing that later when i get home.
  1. V9 with windows 7
    By mriker in forum Mastercam
    Last Post: 11-15-2010, 04:27 AM
  2. x64 windows 7
    By PinnacleMachine in forum Surfcam
    Last Post: 12-30-2009, 03:56 PM
  3. Windows 7?
    By richcam1 in forum BobCad-Cam
    Last Post: 12-20-2009, 09:48 PM
  4. Windows XP or Windows 2000 better with Mach2
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2004, 04:08 PM
