587,006 active members*
3,330 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Ikegai ft20u programming the live tooling
Results 1 to 9 of 9
    Mar 2015
    6
    I have an 80's vintage Ikegai ft20U with a Fanuc 6t B controller, that I am trying to program the live tooling on. My manual gives me little guidance. I have learned that I invoke milling mode by commanding M18. After doing so however I am lost. I can command a M29 C/H__ (spindle orientation) and it orients the spindle, but then it just sits there until I hit reset. the cycle start light stays lit, no alarm, as if it is waiting for some additional command or signal. When I command a tool move such as G01 X__, it just sits there, no axis movement and the cycle start light illuminated but no movement until I hit the reset button. Any suggestions would be welcome or if anyone knows where I could find a program or a manual on programming the rotary tool on this old beast I would appreciate it.
    Jun 2004
    511
    Re: Ikegai ft20u programming the live tooling
    If you are in single block and the cycle start light stays on, it is not done with the block it is on.
    Dec 2012
    395
    Can you post some g-code.
    Try something like this;
    O100 ( DRILL - 5.0MM )
    T0202 G98 M18
    G00 G28 H0 (or C0)
    G97 S3200 M03 (or M13 - M23 ??)
    /M08
    G00 X50. Z10. C0
    G83 R-5. Z-15. Q5000 F300
    C90.
    C180.
    C270.
    G00 G80 Z50. M05 ( M15 - M25 ???)
    G00 X200. Z150. M09
    G99 M17 ?? ( Back to turning-mode)
    M30
    G99, turning-mode, F0.25 (mm/rev.)
    G98, milling mode, F500 (mm/min)
    Or there other codes for Break (High/Low), C-axis ON/OFF ???
    Heavy_Metal.
    1792
    Use G98.
    Aug 2011
    2517
    C-axis and live tool M codes are usually specific to manufacturer. there is no standard so you need the Ikegai manuals.
    The Ikegai programming manual should list all of the M codes.
    Take a photo of that page and post it here then we can help you with the G-Code.
    Mar 2015
    6
    thank you much for your help. i now have some functionality. i would like to find a manual that shows programming for the live tooling on the ikegai ft20 U. Thank You.
    1792
    I do have information about i series Fanuc control, but I don't think it would work on your control the same way.
    Aug 2011
    2517
    the i-series and 6T are 20 years apart! of course it's not going to work.
    you really just need the Ikegai programming manuals for your machine......
    Mar 2015
    6
    thanks for the help. It turns out on this machine that IPM is not commanded with a G98. Instead, G68 commands IPM and G69 is IPR. I could not find any documentation on this, but I figured out that G98 did nothing and so I just started putting in G codes until G68 shifted it to IPM and now I can use feeds when running the rotary tool. I am soooo happy. thank you all.
  1. Problem programming live tooling on G17
    By Toddgiese in forum G-Code Programing
    Last Post: 11-12-2012, 04:16 PM
  2. lathe live tooling programming
    By dynoman in forum Uncategorised CAM Discussion
    Last Post: 12-21-2011, 09:54 PM
  3. Programming Live tooling on Puma Lathe
    By RaceFan in forum Daewoo/Doosan
    Last Post: 04-15-2011, 06:36 AM
  4. Ikegai TUR26 live tooling
    By RGardCo in forum CNC Tooling
    Last Post: 01-23-2007, 05:37 AM
  5. How much does an Ikegai FT20U weigh?
    By protrxrptr17 in forum Uncategorised MetalWorking Machines
    Last Post: 12-14-2006, 02:39 AM
