586,263 active members*
3,916 visitors online*
    Jul 2013
    32
    Homemade cover for VF-11
    We are using a TSC1000 on our VF-11, and we have tons of coolant spraying out of the machine. we have made a light duty cover in the past, but i am wondering if anyone has ever built an aftermarket cover, that would be willing to share some pictures.
    i am currently fabricating a new one, but i am getting stuck on how to finish off the door rollers??? i have a "V" track and some rollers, just need to figure on mounting them...
    we are also installing an aftermarket positive interlock, as our operators seem to think its a great idea to bypass the door interlock.... so this is why i need to figure out how to support the door better.
    and we are also installing a mist eliminator.
    thanks.
    Apr 2005
    713
    Re: Homemade cover for VF-11
    I would install the mist collector first, then see what areas you need to address. The mist collector is likely going to do a better job than you think it will if it's a good brand and is sized correctly.
    Jul 2013
    32
    thanks Matt@RFR.
    we have made a couple pieces for the cover, and are getting ready to install them. i have to lighten them up a bit, and put some lexan in the cover to allow a bit more light into the machine. as for the mist extractor, i think the company is AEROEX mist eliminators (not sure which one)? that's the brand we have on other machines. not sure if they are a good brand or not? they seem to work for what we are doing.
  1. way cover seals
    By mmurning in forum Want To Buy...Need help!
    Last Post: 12-12-2012, 05:48 PM
  2. Looking for x axis way cover for FJV-20
    By pontiacg5 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-28-2010, 03:25 PM
  3. VF2 Z way Cover
    By Mic6 in forum Haas Mills
    Last Post: 07-10-2008, 08:18 AM
  4. Way cover repair?
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 09-12-2006, 04:14 PM
