586,138 active members*
3,418 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > total hours ran on machine esl6
Results 1 to 13 of 13
    Jan 2015
    5
    I was wondering if someone can help me step by step, to get to a page on the okuma esl6 that will tell me the total hours the the machine had been on/ran I seem to only get the total hours ran/on on programs not the actual machine life itself thank you
    Aug 2011
    2517
    Re: total hours ran on machine esl6
    which control?
    Jan 2015
    5
    Quote Originally Posted by fordav11 View Post
    which control?
    Ops u10L
    Aug 2011
    2517
    In the Parameter Set mode, press F7 (item down) until you see the NC Work Counter screen
    Then press Page Down key to see the NC Hour Meter screen. This screen shows the total power-on time.
    The Work Counter screen is an option so if you can't find it by pressing Item Down while in the
    Parameter Set mode then you don't have that option and therefore it's impossible to know the total power-on time.
    Jan 2015
    5
    Darn it I guess I don't have that option on these okumas thank you for your help
    Feb 2009
    6028
    Thought those had MacMan? Iknow the 7000 did, can't remember if those do. It would be in there if it does. (top right of MDI keypad)
    Aug 2011
    2517
    MacMan is pretty useless. It's a sales gimmick to impress a boss who is buying the machine but has no clue about anything in the real world. Definitely no total power-on info in MacMan.
    It has total time power is on for a job but no total total power-on time. It has a work counter but it can't be reset except by loading a new program (which also resets the power-on time for that job) so even that is useless.
    It's essentially for monitoring the current job progress time (cycle time, cutting time, non-cutting time etc) and quantities in a fantasy world where virtual reality becomes reality.
    The Work Counter is an option and the Hour Meter page comes with it.
    No Work Counter means no Hour Meter.
    I asked our Okuma sales/repair guy about it many years ago and that's basically what he said.
    Feb 2009
    6028
    Actually Macman does for sure have total power on time, machine running time etc. All in there, just did a pm 2 weeks ago and part of that was documenting hours.
    Aug 2011
    2517
    Not according to my manual or at least not that I can see from a quick browse of it.
    It looks like the Power-On time shown in MacMan is reset when a new program is loaded.
    I could be wrong ;-)
    I know for sure the OSP-7000 version doesn't have it because I have checked it on my machine and our Okuma guy said Power On Time is via the Work Counter page.
    Here's the OSP-U10L MacMan manual (can't attach it, get error file is too big despite upload window saying allowable pdf file size is 4GB)
    https://www.dropbox.com/s/fxahsa8m7g...anual.pdf?dl=0
    No mention of total machine power-on time there. Only a mention of total machine power-on time per job and per day.
    I'm curious to know what page is mentioning a total power on time since the machine was installed....
    Feb 2009
    6028
    I just did a 7000. It wasn't one of the first pages, I have the instructions, but I remember having to go to macman, and using f4 and paging down. Showed something like 2,200 hours on time, 700 cycle time etc.
    Aug 2011
    2517
    now I'm curious.
    2200 isn't much though. at 8 hours a day that's only 275 days. so not even 1 year.
    it would be possible to get that as a power-on time for a macman session if the machine was not switched off for a long time.
    my machine was built in 1995 so it should have a power on time of about 50000 hours.
    I'll have a look on my machine tomorrow.
    Feb 2009
    6028
    None of our machines are high hours. Only R&d jobs.
    Aug 2011
    2517
    ok well I checked my machine (OSP7000), pressed every button in Macman, page down, F4 on every screen and page on every screen (and every other F button). no Total Time anywhere.
    have you got the procedure to get to the Total Time info?
  1. Fanuc 18i - Total hours reset on its own...
    By JoeCraftsman in forum Fanuc
    Last Post: 08-27-2013, 04:39 PM
  2. Total Working Hours
    By dlange in forum CNC Machining Centers
    Last Post: 12-01-2010, 03:14 PM
  3. How to find total hours on hs1
    By The CNC Noob in forum Haas Mills
    Last Post: 09-09-2009, 11:50 PM
  4. Total Hours on Machine
    By binzer in forum Fanuc
    Last Post: 05-29-2007, 03:17 PM
  5. 3 hours on the machine, or....
    By Twistr in forum News Announcements
    Last Post: 06-08-2005, 11:20 PM
