Hi Tom
I just noticed one more thing...
I wrote a c- program to adjust tool offset of the active tool on my lathe through MSG Boxes. The reason for this is that when you cut a diameter and you notice that the diameter is off by, let's say a value of x you want to adjust the tool offset by the value of x - so it cuts the intended diameter next time.
After changing the tool offset in the tool table with a C-program, the DRO's do not update to the new offset. They get applied only if I do a tool change to some other tool and back. I think it would be very handy if the DRO's would reflect a change in tool offset immediately. I only tested it with the x-value so far.
Also I noticed if that a longer string in the MSG Box does not display fully and can get cut of. If my memory serves me right the same string was displayed at an earlier version (I am using 4.33k). But I am not sure.
Regards
Leo
