587,006 active members*
2,894 visitors online*
IndustryArena Forum > CAM Software > Mastercam > 85 mori sl-2h and mastercam issues (new to this machine with this software and lost)
Results 1 to 7 of 7
    Mar 2015
    5
    I'm working on an old mori seki sl-2h lathe and using mastercam x4 to do a full radius front end of a part. The post is made for a positive x value machine so it post to all positive x and I have to change the positive x to negative x for the machine which programs in negative x. Im using G03 and the radius seems to want to run inverted, least thats what looks like will happen. Do I need to change my r value to a negative in order to get the center point in the proper quadrant?
    Nov 2005
    196
    Re: 85 mori sl-2h and mastercam issues (new to this machine with this software and lo
    Try setting up the tool to point upwards & select the geometry on the bottom half off the part. Make sure you set the tool home position to a negative X.
    Here's the code I got:
    O0000
    ( T )
    ( MAR. 24, 2015 - 12:44 PM )
    (TOOL - 2 OFFSET - 2)
    (OD FINISH RIGHT - 35 DEG. INSERT - VNMG-431)
    M53 G28 W0.
    T0202
    G97 S700 M04
    G0 G54 X.0313 Z.1
    G50 S700
    G96 S600
    G99 G1 Z0. F.005
    G2 X-2. Z-1.0156 R1.0156
    G1 Z-2.
    X-2.1414 Z-1.9293
    G28 U0. W0. M05
    M52
    M30
    Mar 2015
    5
    Quote Originally Posted by Technical Ted View Post
    O0000
    ( T )
    M53 G28 W0.
    T0202
    G97 S700 M04
    G0 G54 X.0313 Z.1
    G50 S700
    G96 S600
    G99 G1 Z0. F.005
    G1 Z-2.
    X-2.1414 Z-1.9293
    G28 U0. W0. M05
    M52
    M30
    First of all, thanks for your response. So, a negative x machine would swap g02 and g03? I see what you are saying and it makes perfect sense. So just do the drawing in the proper quadrant with tool face up so the spindle rotates in the correct direction with the tool upside down on the other side?
    Nov 2005
    196
    I'm not familiar with your machine so I don't know if the spindle will be going in the correct direction. It'll be a lot easier to swap M03 & M04 than change every X dimension from neg to pos & pos to neg. I'm pretty sure swapping spindle direction is an easy edit in the post.
    Is the turret on this machine above or below centerline?
    Feb 2009
    6028
    Just reverse the axis on the machine to make it a X+ machine. See my response on your post in the Mori forum.
    Mar 2015
    5
    Your idea here worked. I just had to tell it upper left yet draw in lower left. Thanks big time. I didnt get to try it until saturday. I work a side job at a buddies shop over the weekend and this is one of his machines. His guy up and quit so for me this is a nice gig. At my main shop Im the plant manager but I hate it and miss working on things. This is my first plunge back into cnc in 4 years and here in the main shop its either mazotrol or gibbscam so going into a different shop, learning different machine with a different system is very exciting.
    Nov 2005
    196
    Glad it worked for you. Underthetire may have a better solution for the long term. Any programs written after his solution will be compatible with other/ future machines in the shop.
  1. Mori TV30 Drill/Tap XYZ Zero Location Lost
    By JerryH in forum Mori Seiki Mills
    Last Post: 10-09-2014, 04:05 PM
  2. Mori SL3H lost my rapids/home/jog
    By spock in forum Mori Seiki lathes
    Last Post: 06-25-2014, 05:52 PM
  3. looking for lost parameters for mori-seiki
    By landcfab in forum Machinery Manuals / Brochures
    Last Post: 06-18-2012, 05:23 PM
  4. Mori SL3 H Fanuc 10T F lost parameters and now almost runs well
    By rolandkra in forum Mori Seiki lathes
    Last Post: 07-11-2011, 09:01 AM
  5. Mori NV5000 lost X,Y,Z,W zero reference
    By teal854t in forum Uncategorised MetalWorking Machines
    Last Post: 08-25-2007, 02:34 PM
