586,608 active members*
3,500 visitors online*
    Mach3 unexpected plunge after tool change
    Ok new to Mach3 and a Tormach 1100....
    Use Haimer to zero x,y,z and then a new tool is loaded
    The tool table is correct for both lengths but it seems that the machine want's to plunge at start as if it thinks the tool is much shorter...
    If I zero on the tool in the Z it works fine
    Any ideas on what I should check?
    thanks
    Feb 2012
    26
    Check you code for tool length offset calls. Some CAM put thrm in automatically
    Quote Originally Posted by CabinDigital View Post
    thanks
    Mar 2015
    17
    Re: Mach3 unexpected plunge after tool change
    Did you ever get this one figured out? I may be having the exact same problem.
    We decided to move to the Tormach PathPilot and it has been 100% good!
    It took some time to get use to Path Pilot but in my view it is WAY better than Mach3.
    Rich
    Nov 2012
    27
    Quote Originally Posted by trogan View Post
    Look for and remove the G43 (length offset) if you don't need it. Check the 'next' Z line after the tool change, make sure it's not changing with regards to the actual tool length and Z clearance.
    I've broken more than one expensive cutter with the G43 command being added during the programming phase.
    15362
    Quote Originally Posted by millerized View Post
    You are doing something wrong if G43 is causing you a problem it should always be in use
    This is an old thread, you may not get a reply
    Mactec54
  1. Need Help - Tool change position mach3
    By extsuba in forum Mach Mill
    Last Post: 04-11-2016, 07:47 PM
  2. Replies: 9
    Last Post: 02-21-2014, 02:55 AM
  3. Unexpected behavior from Mach3
    By kievari in forum Mach Software (ArtSoft software)
    Last Post: 11-21-2013, 03:26 PM
  4. X2 + mach3 - manual tool change??
    By touser in forum Mastercam
    Last Post: 03-02-2008, 07:56 PM
  5. tool change with mach3
    By timmyb199 in forum Vectric
    Last Post: 10-18-2006, 11:29 PM
