586,741 active members*
3,344 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > A2100 using ATX power supply
    Dec 2006
    585
    Does anyone know if the A2100 uses the -5VDC at about 0.5 amps of the AT power supply or can I use a newer ATX power supply with the correct wire connector that does not have a -5VDC output. Has anyone done this in the field??
    Oct 2011
    205
    Re: A2100 using ATX power supply
    Yep, both my 2100's have atx power supply's in them . Get this adapter....ATX2ATPOW from Startech.com
    Dec 2006
    585
    coop31,
    Thanks for the info, I ordered 4 adapters. The old AT power supplies are getting hard to find and some are crappy. I use Startech supplies and have been very happy with them, but I was not sure if the A2100 used the -5 VDC supply.
    Mike http://cncmachineservices.com
  1. Replies: 15
    Last Post: 10-29-2013, 12:58 AM
  2. Replies: 1
    Last Post: 03-20-2013, 05:22 PM
  3. A2100 psu power supply and floppy drive
    By REBCOMACHINE in forum Cincinnati CNC
    Last Post: 10-17-2011, 11:13 PM
  4. A2100 Power Supply Malfunction
    By icesoft in forum Cincinnati CNC
    Last Post: 10-01-2009, 01:31 AM
  5. A2100 auto power off possible?
    By sunnybank in forum Cincinnati CNC
    Last Post: 09-18-2009, 01:26 PM
