586,822 active members*
3,183 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Setting Vref---when?
    Jun 2006
    217
    I received my 4 axis drive with power supply. I set the power supply output voltage and now want to set the drive output. Do I need to be connected to a computer
    with a program running to do this? It seems like I might by the instruction
    sheet. I'm a bit confused. The instructions create a lot of questions for me. I read back to Aug of 2005 on this and can't seem to get clear answers and some of the questions were not answered at all by others.
    Did you read this? http://www.xylotex.com/Setup%20Instructions.htm
    Steps 7,8, and 9. You don't even need the board connected to the computer to set the VREF. (Step 19)
    Jun 2006
    217
    That's 1 Ger21.....0 monte55
    I was going to do it one step at a time so I didn't read too far ahead so I wouldn't get confused. The second step was get the software setup and that threw me off. Some of this I read means nothing to me as I'm sure it will as I progress along. Thanks for the reply.........Nick:withstupi
