586,470 active members*
3,209 visitors online*
Results 1 to 11 of 11
    Nov 2008
    50
    Path Pilot - Rasberry Pi 2 b
    Has anyone tried to run the new Path Pilot on a Rasberry Pi 2.0b? With a quad core processor and enough ram you should be able to correct?
    Feb 2015
    Re: Path Pilot - Rasberry Pi 2 b
    I have a Raspberry Pi 2 b and would love to test this out but have no Path Pilot license and don't own a Tormach. An
    Sep 2009
    1856
    would it run linuxCNC 2.7
    http://danielscnc.webs.com/
    [SIGPIC][/SIGPIC]
    Dec 2013
    267
    I don't believe there is a PCI-e interface for the FPGA card and the PathPilot distro seems to be tightly coupled with the card.
    I have never worked with Raspberry Pi before, but I pulled the specs from: Raspberry Pi 2 Model B | Raspberry Pi
    Feb 2009
    237
    I may be brain-farting here, but I am under the impression that just because you have a Linux distribution, doesn't mean you can install it in whichever processor you want. Path Pilot is based on Linux which was compiled to operate on an Intel CPU. As a result, the machine language will ONLY work with an Intel CPU.
    Raspberry Pi's, on the other hand, are ARM cores and rest assured the instruction set is 100% different.
    Now, with that being said. If you take the source code for Linux 2.7, and you do your Linux magic (for which there are not too many wizards on this planet and this is not to be thought of as a simple task), then you should be able to compile Linux CNC 2.7 for the Raspberri Pi. Sounds like an awesome project to me! Hardware could be devised to transform a Raspberri Pi into the ultimate CNC controller! Heck, all the required processing power is already there...
    I document my CNC Experience at CNC Dude's Youtube channel. Check it out!
    Dec 2013
    267
    Quote Originally Posted by CNC-Dude View Post
    There are already Linux distros compiled for the Raspberry Pi that will support LinuxCNC, however, probably not PathPilot.
    PathPilot ships as a pre-installed OS (Ubuntu 10.04) that is bundled up as a disk image on a bootable DVD. It will only deploy to an x86 based processor. Additionally, I'll reiterate my previous concern that there isn't a PCI-e bus to plug the hardware card into =)
    Of course, if you don't mind running the native LinuxCNC with a USB interfaced driver, I see no reason it shouldn't work with the Tormach. Keep in mind this wouldn't be PathPilot though and you would lose access to the Tormach-specific additions to LinuxCNC that make PathPilot what it is.
    Aug 2014
    42
    There may also be license issues involved. Just because Linux is open source and LinuxCNC is open source doesn't mean PathPilot is open source. Even if it might be eventually, Tormach hasn't released it as such yet. I don't think they're yet willing to sell it to someone without a Tormach machine.
    Nov 2007
    2151
    Quote Originally Posted by burdickjp View Post
    By trade marking the name, hints at this being a future product sold and supported for use on other machines.
    Just guessing
    md
    Aug 2014
    42
    Quote Originally Posted by mountaindew View Post
    Just guessing
    md
    Maybe it's in the cards, but I could see the support necessary for doing so being a very large mountain to climb.
    But I oh so want it.
    There are no USB boards that work with LinuxCNC, are there?
    Jun 2013
    1041
    I don't think it's finalized but k-motion has some members on Yahoo who have been working on a Linux cnc setup with some success.
    Ben
  1. Question about Path Pilot
    By RA-Bowtie in forum Tormach PathPilot™
    Last Post: 01-18-2016, 06:59 PM
  2. Welcome to the Path Pilot forum!
    By kstrauss in forum Tormach PathPilot™
    Last Post: 03-13-2015, 01:41 AM
  3. Anyone here dual boot mach 3 and path pilot?
    By Stevos758 in forum Tormach PathPilot™
    Last Post: 03-11-2015, 01:37 AM
