586,537 active members*
2,933 visitors online*
    May 2008
    83
    ball screw and nut information
    I just purchased ball screws and nuts from charter oak. I am trying to figure out where they are from as I need to figure out the ball nut dimensions for creating a mounting block for. would anyone happen to have that information? I found something online that says Rockford, but when I go to their website neither the pictures or numbers add up to the actual dimensions of the screw and nut. I also tried Nook ind, the images of the nuts look like the right ones, but the dimensions don't add up either. the nuts look to be a single preloaded nut around 2 - 2-1/2" long. when I check the diameter it measures 1.370
    Nov 2006
    40
    Re: ball screw and nut information
    I bought mine from a fellow Zone member a few years ago and he said they were from an IH CNC mill. They came from the company in the following link. Not sure if this will help, but you should be able to search the numbers from the laser markings on your ballnuts. Good luck.
    Metric Ball Screw Assemblies, Imperial Ball Screw Assemblies
    May 2008
    83
    Quote Originally Posted by endo47 View Post
    I am think that is right, the pictures and dimensions are matching. At least now I have the information to machine the mounting block for the but. Thank you for the lead.
    Jun 2006
    3063
    Did you try asking Charter Oak?
  1. Ball nut arbor size for 1605 ball screw
    By kdoney in forum MetalWork Discussion
    Last Post: 04-08-2020, 07:45 AM
  2. Z axis to ball screw or not to ball screw
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 03-28-2012, 09:39 PM
  3. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 05:15 PM
  4. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  5. acme screw to ball screw question
    By Billw in forum DIY CNC Router Table Machines
    Last Post: 07-18-2005, 06:10 AM
