586,779 active members*
9,342 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CNC (Mill / Lathe) Control Software (NC) > What options are there for a double closed loop servo control?
Results 1 to 11 of 11
    I am looking for a system that will allow double closed loop control.
    1st Loop = Absolute rotary encoder on the shaft
    2nd Loop = Linear scale on the table
    Is the second loop typically closed back to the drive or back to the controller?
    Anyone know a way to accomplish this without a fanuc controller?
    Jun 2013
    1041
    Re: What options are there for a double closed loop servo control?
    K-flop and kanalog will do it. Maybe even just k-flop if you close the first loop in your drive.
    Ben
    Aug 2013
    194
    If you're not running Mach then Mesa hardware is also an option
    Why was this moved to the software forum? I am asking about a motion controller and servo drive /servo setup that would allow me a double closed loop. I am asking about hardware. Software will be determined by the hardware choices available to accomplish this.
    35538
    There is the only "general" motion controller section.
    Do you have a preferable one?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2009
    6028
    Fanuc will do it a$$ well.
    Dec 2003
    24223
    There is an instructional video on the Galil site outlaying details on tuning the PID loop between the two encoders to prevent oscillation when some B.L. is present.
    Al.
    Albert E.
    Between kflop and galil what would be the better choice?
    Dec 2003
    24223
    I have mainly used Galil, but there is no CNC front end for Galil besides Camsoft unfortunately.
    Al.
    Albert E.
    Jan 2010
    4
    Al,
    So if I have a DMC 4040, there are few options to make a router/mill other than Camsoft?
    Or maybe the Mach3 plugiin?
    Dave
    Dec 2003
    24223
    I have not used it with Mach but the Mach forum should have details if it is compatible.
    Al.
    Albert E.
  1. Replies: 0
    Last Post: 03-13-2012, 11:15 PM
  2. New 6-axis Double-Closed-Loop Controller?
    By brccrb in forum News Announcements
    Last Post: 03-05-2009, 04:46 AM
  3. CNC Brain is ready! 6-axis Double Closed Loop Controller
    By brccrb in forum CNC Machine Related Electronics
    Last Post: 02-02-2009, 02:47 PM
  4. CNC Brain is ready! 6-axis Double Closed Loop Controller
    Last Post: 09-18-2008, 01:42 AM
  5. question on closed loop vs open loop (servo systems)
    By boonie in forum Servo Motors / Drives
    Last Post: 11-09-2007, 07:30 PM
