Well there you go, don't blame Cut Link as it was your Stock To Leave. That's not strange at all as the tool dialog will always override the cutting dialog.
Jason was on the right path.
The drive surface problem I can't quite understand what you are trying to achieve.
Can you make a new thread about that, attach an example model and describe what you can't do with it?
