587,072 active members*
3,035 visitors online*
Page 5 of 8 34567
Results 81 to 100 of 142
  1. #81
    Jun 2007
    Hi, does anyone have any real plans which they would not mind sharing, as I would like to make a EDM with 3 axis CNC control, regards Steve
  2. #82
    Sep 2006
    6463
    3 axis CNC control....Hmmmmm.....the EDm produces the cavity etc by using a formed copper/graphite etc electrode, during which the end is gradually eroded away also, but the cavity formed is the shape of the electrode, unless you mean that the electrode is a square or round section and the form is produced by weaving around a shape under CNC control, which means then that all you need is the EDM circuits and the rest is normal CNC layout?
    There are real plans to produce the sparking process, but they are pretty standard anyway.
    Ian.
  3. #83
    Feb 2007
    592
    I would also like to build a 4 axis CNC Sinker type EDM.
    When I say 4 axis I will use a spindle electrode holder which can function as an orbiter or as a controlled "C" axis - such as might be used to burn transfer ports in the cylinder sleeve of a 2 cycle engine.
    3 axis helical moves with a rotating spindle allow "thread milling" type burning of thread forms in full hard materials.
    There don't appear to be any functional public domain or open source plans out there. The power stage I will be using is proprietary, don't ask me to give away something that isn't mine to give. As to the control side I have high hopes that at some future point EMC2 can be adapted as the CNC control, but there are many unique to the EDM process issues which will still require much developement.
  4. #84
    Oct 2005
    1237
    How do you do that? EDMs of the sinker variety have limitations. You can make threads by using a thread form electrode and a tapped greenboard guide. The Z axis has a rotary head that spins on center, and drives the threaded electrode in and out of the greenboard and into the work. Electrodes wear very quickly compared to a mill. I just don't see how you could make four axis work with a sinker. A wire EDM is different.
  5. #85
    Jun 2005
    199
    Quote Originally Posted by bones View Post
    Hi Guys,
    I saw a wire EDM running today and it is very impresive.
    I don't think an earlier question was answered but cutting 2mm plate it was using 110V and about 0.5amps.
    They had the settings on the machine for higher currents.
    It was orsm to watch and the 6M of wire reeling itself on one wheel reversing and reeling itself back.
    The machine was very solid castings but I think one can be built failry easily.
    There is no force on the job. It just has to be held.
    It was 4-Axis too. You can make a pyramid from solid steel.
    The job was held by 2 rails and water was pumped to either side of the job.
    Spraying on the top and bottom.
    I'd like to try and build one after the next 2 projects.
    Cheers
    Rod
    Anyone interested in making one of these can find complete details and drawings in "The Model Engineers Workshop Mag. issue 95-96 and 97. The article is by Peter Rawlinson.
    wjf
    The More I Learn The Less I Seem To Know
  6. #86
    May 2008
    edm plane
    edm-power.pdf
    Quote Originally Posted by Predator View Post
    really interested and appreciate if you can email the edm machine building guide as well!
    [email protected]
  7. #87
    May 2008
    edm-power.pdf
    Quote Originally Posted by Blaugen View Post
    hello friends:
    I write to request them circuits (plans) to build a pulse control EDM. I allready made one, but is a metal desintegrator tap remover, with a series of Resistors and capacitors, but I want to build one better than this, with a modulator or a pulse control.
    thanks and excuse me my grammatical erros, I´m not american.
    Blaugen ([email protected])
  8. #88
    24223
    This post has been going for a two or three years, has anyone got any comments/feedback on any particular design they have built for a sinker EDM?
    Anyone built the http://homebuiltedm.tripod.com ?
    Al.
  9. #89
    Feb 2007
    592
    Cool The Ben Fleming EDM
    I have mine 70-80% complete.
    It would get done faster if I was able to spend more time at home, but I go where I am paid to go...
    I have Ben's book and his PCB - I much prefer using a real PCB vrs perf board or attempting to fab my own PCB.
    If I were to my own I would likely use a bigger H-Bridge chip to allow slightly larger servos than the ones suitable for Bens Drawer slide design.
    Many members in the yahoo forum have reported successfull builds.
    The Key thing about Ben's book is he gets into the details of using the EDM and preaches the gospel of proper flushing... Its way more than a simple how to writeup.
    Also - Some day a pulsed EDM follow up book has been promised. :stickpoke
  10. #90
    Oct 2005
    1237
    I have both the Langlois and Fleming books. My head is finished but was built with a stepper motor. I ran into trouble making a decent PCB for the stepper control though, so it has sat. After finding the Fleming book with a simpler servo drive, I decided to incorporate both designs into one ideal unit.
    Langlois goes into deeper detail for controlling the burn with a capacitor bank that includes larger capacitors. Fleming has the simpler control and goes into detail for an EDM tank. I have everything I need except a PCB board for the control. Because I already made a precision stepper driven head, I'd really prefer to build Langlois' control, but will probably bite the bullet and find some servo that I can cobble to the stepper mount just to get it done.
  11. #91
    Nov 2008
    6
    dear all
    please I hope to built EDM machine any body can help me for this project
    thanks in advance
    gamal
  12. #92
    Dec 2006
    15
    May I have the plans, too?
    Thank you very much.
    Santafesonido from Argentina
  13. #93
    Dec 2006
    15
    sorry ,the mail
    [email protected] tanks you
  14. #94
    Sep 2006
    6463
    Hi Gamal, post your email adress and I'll send them to you direct.
    They were posted previously in the first one or two pages on this thread.
    Ian.
  15. #95
    Nov 2008
    6
    Dear IAN
    thank you for answer my mail is ([email protected])
    thanks
    gamal
  16. #96
    Jul 2007
    21
    I would like to get the plans. By the way, I can offer a book from a Russian that invented the EDM where he explains all the different factors affecting sinking EDM. By the way I also would like to know if any of the plans include an EDM by pulse (not R-C circuit)
    [email protected]
  17. #97
    Sep 2006
    6463
    Hi gmolteni, The plans are for a straight forward die sinker type that uses a stepper motor drive to peck the form out controlled by the circuit.
    If you are familiar with electronics maybe you can modify the circuits and post a plan for an update to the system.
    I'll send them as is to your email adress.
    Ian.
  18. #98
    Jun 2005
    4
    Hi Handlewanker
    Can I also have one of your plan please?
    my email address: [email protected]
  19. #99
    Jul 2007
    21
    Thank you very much for the plans Handlewanker.
    I found most of the information about EDM very light, not going deep on practical information.
    I uploaded a very interesting russian book (english edition of the book) about sink EDM http://www.esnips.com/web/mecanica3
    Although the book is rather old, (in fact is one of the first scientifical studies about the subject) is very interesting the way the matter is covered, perhaps it would be useful for someone else.
  20. #100
    Dec 2005
    5
    Hi Handlewanker (Ian)
    Can I also have one of your plans too?
    my e-mail:[email protected]
    I was looking a PDF named "edm-power.pdf" but the output of 7555 goes to nowere ...
    something is bad there
    See you, and thank you in advance for your plans
Page 5 of 8 34567
  1. Needing help with my home built machine.
    By whiteknight5951 in forum Stepper Motors / Drives
    Last Post: 01-05-2014, 01:20 AM
  2. Frame design for home-built milling machine
    By tom.k.cook in forum Drilling- and Milling Machines
    Last Post: 04-09-2013, 08:30 PM
  3. Home built 5 axis machine
    By csmoak25 in forum DIY CNC Router Table Machines
    Last Post: 02-15-2011, 03:56 AM
