587,067 active members*
3,493 visitors online*
Page 3 of 8 12345
Results 41 to 60 of 142
  1. #41
    Jul 2006
    117
    Angry
    Quote Originally Posted by handlewanker View Post
    Hi Sanjiv, don't get too frustrated with waiting for someone to make one of these machines, we're all too busy right now on other projects, but in the meantime we're collecting data and designs so that when the desire to actually make one occurs, then all the info' is there.
    Nothing is stopping you from having a go.
    Remember what Confucius said, "the longest journey starts with asking a few directions from well meaning friends and then goes on to getting some equipment at the local $2 shop and finally when the day arrives and your all fired up and rearing to go, Mum says "go and cut the grass, and then wash the car".
    Ian.
    u r right. i had tried a lot to purchase these books from last year. i tried it on every site which are selling these books. but no body is telling that how much i have to pay so that the books reaches to m,e. i m in India (New Delhi)
    Sanjiv
  2. #42
    Feb 2007
    Looking for home made EDM machine plan
    Can any one mail me plane or any sort of detail to make home made EDM (of course small capacity). I am on the crucial stage and cant offered to buy.
    My e-mail id is [email protected].
  3. #43
    Aug 2005
    132
    Hi Guys,
    I saw a wire EDM running today and it is very impresive.
    I don't think an earlier question was answered but cutting 2mm plate it was using 110V and about 0.5amps.
    They had the settings on the machine for higher currents.
    It was orsm to watch and the 6M of wire reeling itself on one wheel reversing and reeling itself back.
    The machine was very solid castings but I think one can be built failry easily.
    There is no force on the job. It just has to be held.
    It was 4-Axis too. You can make a pyramid from solid steel.
    The job was held by 2 rails and water was pumped to either side of the job.
    Spraying on the top and bottom.
    I'd like to try and build one after the next 2 projects.
    Cheers
    Rod
  4. #44
    Mar 2005
    1136
    Quote Originally Posted by bones View Post
    HiThe machine was very solid castings but I think one can be built failry easily.
    Rod, I agree, but i think easy is a relative term. you need very precise motion control and wire handling mechanisms. although there's no force, the the precision demands a rigid structure, ie no vibration. There's a good discussion in here somewhere, worth searching out. Roysol who posts here knows these machines inside and out and has outlined the basic mechanical requirements and challenges faced.
    I'm going to build a plunge version first, right after i finish the sheet metal brake, grinder dust extractor, spot welder, one shot oiler for mill and lathe, power supply for the pillar tool, cnc lite mill, circuits and power supplfor for same and a couple of engines...god knows why i just ordered material for a V-8. i better live to 150 or I'll be leaving behind one confusing mess .
  5. #45
    Aug 2005
    132
    Hi McGyver,
    Thanks for the info. I'll try and find the the discusion. It's a bit hard with the search engine here as it can't find anything when searching EDM.
    I'd like to start on one after the milling conversion, the router, plastic vacuum molder, another milling machine and then a EDM.
    To many machines to build, not enough time in the day, money and a nagging missis.
    Cheers
    Rodney
  6. #46
    Feb 2005
    51
    could you email to me as pdf...vry interested and would appreciate the knowledge!
    Jimbo
    [email protected]
  7. #47
    Feb 2007
    592
    Cool
    Having run both sinker and wire EDM's on the job... I can tell you it would NOT be a simple task to build a wire machine of more than 2 axis (basically a wire band saw...)
    Sinker machines however can be made rather simple.
    I am building Ben Flemmings design currently for my own use. It is about as simple as it gets. Well not as simple as Jon Elson's (the pico-systems link posted earlier), but it is rather self contained if you consider the tank/pump as a seperate unit.
  8. #48
    Oct 2006
    8
    really interested and appreciate if you can email the edm machine building guide as well!
    [email protected]
  9. #49
    Sep 2006
    6463
    Hi Predator, I've got some pages from the Model Engineer that describe a small EDM for home construction and use.
    I'll email them to you.
    They're pretty basic stuff but if you want to learn about the construction and allied circuitry it'll serve as a start, and if your electronic knowledge is up to it you can adjust the components as you see fit.
    Ian.
  10. #50
    1880
    could i get you to mail them to me as well?
    thanks
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
  11. #51
    Sep 2006
    6463
    Hi miljnr, add your email adress and I'll send them to you direct.
    Ian.
  12. #52
    Apr 2007
    641
    Please can I have the plans too?
    [email protected]
    Luis
  13. #53
    Apr 2007
    641
    Thanks Ian, for the plans
    i'll spend the nigth with a new toy....
  14. #54
    Apr 2005
    19
    May I have the plans, too?
    [email protected]
    Thank you very much.
    Tan
  15. #55
    Mar 2007
    8
    hi kindly send me an edm plan with high voltage production in edm thanks
  16. #56
    Feb 2007
    16
    I would love a copy if you don't mind.
    David
    [email protected]
  17. #57
    Sep 2006
    6463
    Hi Balwinder, let me have your email address and I'll send them direct to you.
    Ian.
  18. #58
    Jul 2003
    586
    are these plans for a wire edm? if so i am in.
  19. #59
    Sep 2006
    6463
    Hi 4th, the plans are for a conventional "peck & burn" type. More of a model makers toy but the principle is sound and if you apply the design & circuitry to a more advanced design it will give you something to experiment with.
    Ian.
  20. #60
    Jun 2004
    [email protected]
    Juhannus from Finland
Page 3 of 8 12345
  1. Needing help with my home built machine.
    By whiteknight5951 in forum Stepper Motors / Drives
    Last Post: 01-05-2014, 01:20 AM
  2. Frame design for home-built milling machine
    By tom.k.cook in forum Drilling- and Milling Machines
    Last Post: 04-09-2013, 08:30 PM
  3. Home built 5 axis machine
    By csmoak25 in forum DIY CNC Router Table Machines
    Last Post: 02-15-2011, 03:56 AM
