586,983 active members*
4,109 visitors online*
    Mar 2015
    5
    Wood Boat Frames- already laid out just need cut
    I need 8 sheets of .75" 4'x8' marine grade plywood cnc routed. Parts are already laid out in DXF format on a 4'x8' sheet. Just need cut. All vectors are closed. Please see attached file.
    I need a quote for materials AND for labor please.
    Please PM me, email me at [email protected], or call (919)817-2795. My name is Alex
    Considering all quotes nationwide. Thanks
    Mar 2015
    5
    Re: Wood Boat Frames- already laid out just need cut
    Or just for labor/cutting and I can have materials shipped to you.
    6855
    what state are you in?
    Mar 2015
    5
    Quote Originally Posted by cncadmin View Post
    NC. Thanks
    Feb 2007
    711
    I would try to quote this if it would fit my machine, unfortunately I only have 48 x 48.
    Others may want to know what kind of radius is acceptable on the sharp inside corners, the way it is drawn only a laser or waterjet would work.
    Mar 2015
    5
    Quote Originally Posted by alan_3301 View Post
    Thanks for the tip, Alan.
    As far as tolerances, we are only needing within a 1/32". The radius for inside corners is not a concern, as everything will be hand sanded once we receive the piece. To throw out a tolerance, I'm fine with having a 1/8" discrepancy on the corners. We just don't want to cut these by hand.
  1. cnc wood frames with metal art inserts
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 09-25-2014, 12:25 AM
  2. cnc wood frames with metal plasma art inserts
    By woodman08 in forum Logic Trace CNC/DXF
    Last Post: 09-25-2014, 12:23 AM
  3. CNC Wood Router For Boat Making
    By omnicnc in forum Omni CNC
    Last Post: 11-19-2012, 08:32 AM
  4. OMNI CNC Wood Router Produce Boat Mould
    Last Post: 10-18-2012, 08:28 AM
  5. Freshly laid off, 9/10/09
    By aaron p in forum Community Club House
    Last Post: 10-29-2009, 05:10 AM
