on our PCNC 1100 we keep it adjusted so that all three axes are less that 0.0005" if it gets above that we will re-adjust it. It takes patience, but it is possible to improve the adjustment. To get all that you can out of the machine can involve looking at all aspects, from the gib adjustment, to the bearing pre-load, to the level of the base of the machine (which i learned the hard way). The bearings you can measure the preload by indicating the end of the ball screw while changing directions back and fourth, if it moves then the bearings are not tight enough (it's kind of a pain to do the Y because of removing the bellows). if you adjust the bearings too tight the machine will make a kind of a bad grumble sound when slowly moving. I think with attention to detail you can achieve much better performance than the tormach baseline specs. We have had little difficulty hitting +/-0.001 and we rae new to machining also. good luck
