586,369 active members*
3,289 visitors online*
Results 1 to 4 of 4
    Aug 2006
    493
    looking for 1/8 end mill with 1"cel
    Wow this forum has grown since I've been on last. Any way I'm looking for a 1/8" end mill to cut out intarsia pieces , The material I'm using is 1"cedar , the only one I found so far is from PreciseBIT Soft Media End-mills!!! but they say I may get some tear out, If any one has cut out thick wood inlays with success I'd like to here from you. I have been using a scroll saw for this so far but would rather use the cnc router. Thanks Graham
    Feb 2015
    174
    Re: looking for 1/8 end mill with 1"cel
    Yeah, one inch deep assuming 1/8 dia. Rough. Make (relieve the shank) one then step down the passes in increments carefully as you now have a "weak" endmill, If it was steel this would be a no brainer. Two mills maybe? First to depth it can handle, second mill, unpredictable speeds and feeds. Am I close? Use an old, tired mill and try something?
    stu
    Jun 2010
    4256
    The PB cutter you referenced is an 'up-cutting' one. That is, it cuts upwards. This can lead to tearing or burrs at the surface.
    Have you tried a 'down-cutting' end mill? They cut downwards and do not tear at the surface. Google for suppliers, but PB do sell them:
    Down-cut Soft Media End-mills
    Cheers
    Roger
    Aug 2006
    493
    Thanks for the reply guys, ill give the pb a try and see how it goes, any of you ever do thick inlay with the cnc ?
  1. Mark's EPOXY Granite 18"x20"x20" (700mmx780mmx780mm) vertical mill build
    By gt40 in forum Vertical Mill, Lathe Project Log
    Last Post: 01-19-2019, 09:26 PM
  2. Replies: 0
    Last Post: 02-04-2014, 02:06 AM
  3. Replies: 21
    Last Post: 01-13-2014, 04:10 AM
  4. "Warco GH Univ" V "Chester Lux Mill"
    By JQ_Quint in forum Benchtop Machines
    Last Post: 01-22-2009, 05:59 PM
