587,195 active members*
2,959 visitors online*
    Sep 2013
    326
    Last post for the week. Ajax Y Motor no stop.
    OK... I'm so close guys! All the tests pass. I even have the Haunyang 3hp VFD running from the Pendant! Here's my question: When I did the motor move tests, the X motor would jog fine. + or - spins the motor. It Stayed locked in position until I hit a limit Sw. On the Y motor, when I hit + or - Just runs and runs. Wont stop till I hit the Limit Sw. then if I hit Jog- IT starts running again till I press a limit on Y. Any thought on this?
    Re: Guess who! Today's issue from CG. Y motor problem.
    Postby countryguy » Fri Mar 06, 2015 3:48 pm
    Hi So I hooked up my belts and drives. Very smooth X and Z movements. The Y drive just took off until it hit the Limit. I've checked the Alt-I input screens and found the 2 axis input lights for + and - to insure that when I use the pendant, the Key is not stuck or anything weird. So what would cause that unless I have something configured wrong? Hope you guy's can help me w/ this one before the week ends as I hoped to actually put steel on this Mill ;-) Well...My Son did anyway. LOL. SO CLOSE!!!
    As a note- I'm also getting a SV_Stall error every time as well..... Did a search on this site. Not really sure what that even means as yet.
    TIA,
    TGIF
    Jeff
    Sep 2013
    326
    Re: Last post for the week. Ajax Y Motor no stop.
    Talked to Support- Noted I probably have the Motor + and - leads reversed. That its goes 1 way (wrong way) expects encoders the other way - Get lost till it hits the stop. Makes sense. Noted to also check the Encoder count direction. Make sure counter-clockwise goes more positive. If backwards, issue a the Drive Reverse setting in config. Kewlness!!! :-) REady to get this thing into gcode and chips soon!
    CG
  1. DolphinCAM post processor for ajax/Centroid mill contoller?
    By countryguy in forum Dolphin CAD/CAM
    Last Post: 12-18-2014, 01:36 AM
  2. E-Stop on axis motor wiring.
    By howanc7 in forum Centroid CNC Control Products
    Last Post: 03-08-2014, 08:25 PM
  3. Stepper Motor Starts and Stop
    By crodriguez1517 in forum Stepper Motors / Drives
    Last Post: 04-30-2012, 03:39 AM
  4. Ajax post??
    By Lasershop in forum Surfcam
    Last Post: 02-08-2009, 07:11 PM
  5. Spindle Motor Stop
    By rweatherly in forum Mach Software (ArtSoft software)
    Last Post: 11-25-2006, 05:28 PM
