586,290 active members*
3,834 visitors online*
    Aug 2014
    29
    Angry Milling issue
    On the file that I uploaded, the top is the only part that I need help with. I am trying to remove about 2mm off the top while leaving the 2 cylindrical parts. I have been trying to figure out how to make the toolpath for it, but it keeps wanting to either mill out the 2 circles, or it mills the whole face down. Can anyone point me in the right direction?
    Apr 2009
    3376
    Re: Milling issue
    I see nothing in file,it is blank ????????
    Feb 2015
    174
    Re: Milling issue
    Ya, seems to be an issue in the file, DXF maybe? cad, DXF, some other extension related?
    Dec 2011
    295
    Re: Milling issue
    Without a part I would say you need a pocket strategy. Make a boundry bigger than the whole part. Select pocket strategy and select the boundry and the two islands for your geometry. You might have to change direction of feed. Make sure the end mill can fit between the islands.If you get stuck, fire back....here to help.
  1. V-Groove Milling issue
    By CYoung in forum BobCad-Cam
    Last Post: 10-24-2014, 01:15 AM
  2. Hex Milling Issue
    By yz85608 in forum Mastercam
    Last Post: 04-03-2012, 03:48 PM
  3. Cambam issue or Mach 3 Issue??
    By tracyranson in forum CamBam
    Last Post: 07-11-2011, 04:03 PM
  4. SprutCAM 7 Milling Issue
    By Pat_IS in forum SprutCAM
    Last Post: 07-16-2010, 01:00 AM
  5. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
