586,991 active members*
3,923 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1
Results 1 to 20 of 34
    Jan 2009
    334
    Hello all!! I have been very busy working on several projects, iBOB1 and iBOB2 break-out boards. I have started retrofitting a Denford NovaTurn CNC Lathe. I will be replacing the Sanyo Denki stepper motors with Yaskawa AC servos 100W. The control will be closed loop using the industrial +- 10V standard.
    My goal is to move Gizmosphere out of the hobby world to the industrial.
    I will post more pictures and video soon. If you want to see some basic video please go here;
    CNC
    https://www.youtube.com/watch?v=Zg8HZzmHRtQ
    Sound Card
    https://www.youtube.com/watch?v=E1Xj6C5Uq2I
    Attachment 271298
    I have demonstrated Ubuntu 10.04, LinuxCNC and Windows 7, 32bit-MACH3 using a MESA 6i25 for closed loop analog servo control and a PCIe x1 parallel port card ( MosChip MCS9901) to breakout board for open loop stepper control.
    In a previous post a few years ago at Denford, the unit does not have the controller cabinet. I am designing a new unit. It will be very small based on the Gizmosphere 1. This small size controller will allow the Gizmosphere to be used in industrial applications and control upgrades/retrofits.
    The Gizmosphere is approx 3.96" x 3.96". The iBOB2 is approx 2.5" x 2.56" in size and breaks out 1 PCIe x1 and 1 SATA port .
    I hope to make these boards available for sale. A very basic website is located here; Home
    I welcome any comments or thoughts.
    Robert Blanton
    Jan 2009
    334
    Re: Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1
    Just finished the new X axis servo motor plate. I used my converted Sherline Mill with DC servo amplifiers that I built/designed a few years ago. If anyone is interested, please let me know. Most of the initial work is posted on CNCZONE under Iron-Man Servo. I will be powder coating the parts. I have already started the new design for the Z axis servo plate.
    Attachment 273016
Name:	Yaskawa Servo Plate X Axis 2015-03-19 17.45.17.jpg
    I welcome any comments.
    Jan 2009
    334
    Completed Z Axis Servo plate. X Axis Servo plate trial fit. The Z Axis did not come out as planned. I may redo it. I will also be retrofitting a Denford Triac Mill with Allen Bradley AC Servos.
    Attachment 274826
    Attachment 274828
    Attachment 274830
    Iron-Man
    Jan 2009
    334
    Picture of iBOB2. The iBOB2 turns the Gizmosphere 1 into a powerful CNC controller. You can attach Mesa cards, parallel port cards are any PCIe compatible card.
    Attachment 275190
    Nov 2009
    4415
    Quote Originally Posted by Iron-Man View Post
    Attachment 274826
    Attachment 274828
    Attachment 274830
    Iron-Man
    Is this mounting plate (the top picture) powder coated? If it is, why do you want or need it powdercoated? From the pic it appears to be pc'd.
    You do nice work, keep posting.
    A lazy man does it twice.
    Jan 2009
    334
    Quote Originally Posted by Fastest1 View Post
    It is not power coated yet, just polished. Powder coating provides a hard durable finish to protect the aluminum from any oxidation etc. You can see some of my previous powder coating here; http://www.cnczone.com/forums/bencht...3-posts-4.html
    By the way, all of the servo plates were made from the servo amps I designed/made a few years ago. They work great and there is no heating problem with the OPA549 amps.
    Look for Servo Reducer High Res Image.
    Iron-Man
    Jan 2009
    334
    iBOB2 proof of concept, Gizmosphere 1 high speed;
    I plan on providing these for sale. So if you have a Gizmosphere 1, hold on to it. In a few weeks I will be showing a complete CNC solution based on iBOB2 and Gizmosphere 1, i.e. open source Linuxcnc and Gizmosphere.
    Iron-Man
    Jan 2009
    334
    Gizmosphere 1 I/O shield. From This:
    Attachment 275656
    Attachment 275660
    To This, Polished:
    Attachment 275662
    Attachment 275658
    Attachment 275664
    Jan 2009
    334
    Servo plates powder coated and ready for install. Currently working on the CNC controller.
    Gizmo 1 I/O Plate
    Attachment 280882
    X Axis Servo Plate
    Attachment 280884
    Z Axis Servo Plate
    Attachment 280886
    Jan 2009
    334
    This is what I have in mind for the control panel. I hope to build my own tool changer and C axis. The Gizmosphere will eventually be located inside this cabinet. The cabinet was not available when I started initial design work. The DC drive is a 4 quadrant "servo motor" drive.
    Attachment 281618
    Attachment 281620
    Attachment 281622
    Attachment 281624
    Attachment 281626
    Jan 2009
    334
    Cleaning up the NovaTurn and bellows. First custom I/O cable completed. Working on the CNC controller and testing servo motors.
    Iron-Man
    Jul 2015
    Hello Robert,
    you have send me an email but I can't respond your email adress...?
    Here is my answer to your question and your machine....
    Hello Robert,
    here you can download the used config:
    https://github.com/aschiffler/linuxc.../machine_cloud
    Perhaps it is difficult to understand. (perhaps erase all commented
    lines for a clear view)
    Here are some preconditions:
    - The drive for the A-Axis / Lathe-Main-Spindle can be switched from
    position control to speed control mode and vise versa
    - In my setup all drives have a digital field bus (ethercat); the
    communication is done via the module "lcec"; lcec.0.6 is the
    lathe-axis-drive.
    - To switch the Operation Mode lathe/A-Axis you "online" you have to
    unhome/home the a-Axis. (Therfore i have added some buttons in pyvcp,
    see vcp.xml)
    Hope that gives some hints to help you.
    The config 'machine_cloud' has add. data logger functionality; see video
    linuxcnc2cloud on my youtube channel for background.
    Regards
    Andreas
    Jan 2009
    334
    Quote Originally Posted by roschi View Post
    Hello Robert,
    Hello Robert,
    lathe-axis-drive.
    see vcp.xml)
    Regards
    Andreas
    Andreas thanks for the information. I am also currently working on a hardware/software solution that would have the spindle as default but switch to A-Axis when selected.
    I should be posting new pictures and video soon.
    Iron-Man
    Jan 2009
    334
    I have been working on a design based on the iBOB2 and Gizmosphere 1. The Dimensions of the GQ1 are Width 6.79", Height 6.61" and Depth 10.29". It has 6 axis of +- 10V analog servo control and all I/O are available on 2 DB50 and 1 DB 25 connector. The RJ45 is for a pendant interface. It could also be made for step and direction. I prefer true closed loop control. I plan on selling the iBOB2 for anyone who wishes to make a ultra small CNC controller or place the complete controller within a small case or enclosure. The small circuit board in the back left is the iBOB2.
    Attachment 289140
    Attachment 289142
    Iron-Man
    Jan 2009
    334
    Oct 2012
    342
    Where did you get this control panel from?
    -Dan
    1943
    Quote Originally Posted by engnerdan View Post
    -Dan
    He built it. As in the pictures right above the one you linked.
    Oct 2012
    342
    Quote Originally Posted by 109jb View Post
    Thanks but I am not that dense that, I can't see or read the posts. That was not what I was asking about, I want to know about the control panel he has mounted in his enclosure. I fixed my post so the picture shows up.
    1943
    Jan 2009
    334
    -Dan
    Dan I found it new, on ebay a few years ago. I am currently connecting the functions to a Mesa 7i77 card.
    The MPG and E stop were added later, also found new on ebay.
    Iron-Man
  1. Anyone ever retrofit a Servo II system?
    By frontrange in forum Post Processors for MC
    Last Post: 04-05-2020, 10:57 PM
  2. AMD Gizmosphere Embedded Computer + iBOB2
    By Iron-Man in forum Controller & Computer Solutions
    Last Post: 02-14-2015, 12:01 AM
  3. Servo Retrofit MAHO 600 P
    By nissse in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 10-25-2011, 07:55 PM
  4. Servo Help, Series 1 Retrofit
    By Jet A in forum Bridgeport / Hardinge Mills
    Last Post: 02-10-2010, 08:40 AM
  5. 3phase servo retrofit
    By whiteriver in forum Servo Motors / Drives
    Last Post: 02-07-2005, 04:27 AM
