587,070 active members*
3,090 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > X Axis Noisy & Rough Stepping. (Video)
Results 1 to 4 of 4
    Jun 2014
    27
    Hi all,
    I still have issues with the X axis with rough stepping at different speeds during a cutting run.
    This is a dummy run to show the noisy stepping as it transitions through a run and this can happen from speeds as low as 40 IPM and up.
    It starts to lose a lot of steps above about 65 IPM in the X axis but the Y and Z will run quite OK up to a 100 IPM without dropping a step.
    This is after adding an Ethernet Smoothstepper overcome a PC issue I had and I'm now running from a Windows 7 Laptop so overall reliability has improved greatly with the Smoothstepper it's just I still have this problem with the X axis. Has anyone seen this problem and fixed it? any help here would be great.
    Video is HERE so you can have a listen to the noise its making. This happens on various GCode from the road runner test to code from Vectric Cut2D, some worse than others, all axis are set the same so there is no difference.
    I'm running a 48V supply to three drivers,
    My normal Mach3 settings are.
    200 steps per mm
    1100 mm/min = 43 IPM
    300mm acceleration
    Thanks for any help offered.
    Nico.
    Attached Thumbnails Attached Thumbnails New-stepper-drivers.jpg   New-Driver.jpg
    Jan 2005
    1695
    Re: X Axis Noisy & Rough Stepping. (Video)
    It sounds like resonance. To confirm, slowly increase the speed from zero. There will be several speeds where the mechanism vibrate.
    Adding a mechanical resonance damper will eliminate the problem.
    Apr 2009
    125
    Yes, resonance. One way they work smoother is to microstep the drives. Assuming 200 steps per mm is 200 steps per revolution of the stepper motor on a 1mm pitch screw, Try reset to 2000 steps per revolution on the drivers and in mach3 set 2000 steps per mm. It should run much smoother.
    Jun 2014
    27
    Thanks guys,
    It's a 4 mm pitch and so I have the driver set to 800 steps per rev so I'll give the next step up to 1600 steps per rev a go and see how it performs.
    I did try this prior to fitting the Smoothstepper and I think it may have even been when I was still running my original driver board, the ubiquitous Toshiba 6560 single board 3 axis board.
    Strange that it's only happening on one drive though, anyway I'll try the easy steps first, micro stepping first, may even swap the X and Y motors just to confirm it's not one of those.
    If that doesn't work I'll make a damper for the motor.
    Stay tuned I guess and I'll let you know how it goes.
    Nico.
  1. noisy x axis
    By fadalman in forum Fadal
    Last Post: 06-10-2013, 04:21 AM
  2. Noisy z axis
    By forseral in forum K2CNC
    Last Post: 04-12-2012, 01:47 AM
  3. Noisy drive axis
    By KTECH in forum Fadal
    Last Post: 06-28-2009, 07:09 AM
  4. Y axis very noisy Changes directions?
    By bcnc in forum Syil Products
    Last Post: 04-02-2007, 01:02 AM
  5. Z axis noisy upon startup
    By BMackinnon in forum Haas Mills
    Last Post: 08-03-2006, 12:36 AM
