I found this suggestion online so I can't take credit but it seems to work.
Is there any problem adding C-axis parameters to Mach3 mapped to the same pins as the Pulsar spindle?
That way I can use the C-axis to do the rigid tapping and still leave the A-axis open for the rotary table, and I don't have to open up the cabinet everytime.
It seems to work out fine - I tried it cutting some air, and the steps/unit are 166 in mach3. I have the C-axis motor speed down to about 100 in/min to keep things nice and slow.
When I type in the commands C20 Z-1.0, it rotates exactly 20 revolutions CW and Z goes down 1 in, just like when I had the A-axis set up like this.
Now if I can only figure out how to get SolidCam to output rigid tapping code - it only seems to have G84 which mach doesn't like.
-B
