586,145 active members*
3,843 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Centroid CNC Control Products > DC-AIO PLC machine Parm #35 what should it be set to?
    Sep 2013
    326
    Sorry guys- Trying to do the Spindle testing. Last item before final config. I am not sure what the value should be for Machine Parm #35. Spindle Axis? I did not record the default when I set it to 0. I assume the spindle axis is spindle 1. Change from a 0 to a 1 for a Mill?? TIA,
    CG.
    Sep 2013
    326
    Re: DC-AIO PLC machine Parm #35 what should it be set to?
    Also, I'm wondering if I need to do something on my DC-AIO for the Spindle speed & spindle encoder count? While I have a VFD wired in, there are some settings for the Spindle encoder count? (34 in machine parm) . I'm not sure if the VFD will know the spindle RPM or if I needed to setup a index pulse of sometype? figured I would ask here and I'll hit more of the manuals later.
    Sep 2013
    326
    UPDATE- So I set it to 1 and the X axis motor would not work. Tried as 6. Same as in the manual image. I get a spindle fault error on start up w/ that. ??? So I dunno. Still working on the Hunyang VFD as well... :-) long day chasing gremlins ;-)
    Feb 2008
    280
    Assuming your machine is a basic milling machine, it probably does not have, and probably does not need, a spindle encoder.
    Spindle encoders are used on machines with tool changers when the tool change sequence requires spindle orientation. A spindle encoder can also be used to support rigid tapping. No spindle encoder is needed for floating (tension/compression) tapping.
    If you have no spindle encoder installed, then you should set Parameter 35 = 0.
    Sep 2013
    326
    Perfect,thanks. Makes total sense! As this is all so new, I get the tests first and the lesson's later on. Life of a new Centroidian.
  1. Replies: 1
    Last Post: 08-03-2014, 07:55 AM
  2. Replies: 0
    Last Post: 04-23-2014, 09:39 AM
  3. Replies: 0
    Last Post: 08-09-2013, 04:03 AM
  4. Replies: 5
    Last Post: 12-19-2012, 02:35 AM
