586,956 active members*
2,796 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > New Kitamura trunion door interlock
    Feb 2015
    Does anyone know where the heck is the setting to disable that annoying stupid lock? Have run machines for years without this and not being able to change tools or basically anything without having the doors shut is a royal pain. Some times you need to open the door and look at a blind spot that you think will hit or whatever.
    This a new machine and app guy wont help either.
    Mar 2010
    1852
    Re: New Kitamura trunion door interlock
    Wrong Forum!
    Feb 2009
    6028
    Your not going to be able short of dissconecting the actual key and shove it in the lock. You may have to pull it out and re install after every M30 as well. Current US ANZI/Osha and NFPA standards do not allow the builders to disable door interlocks. Even the days of the waivers are gone.
    Feb 2015
    Quote Originally Posted by Machineit View Post
    Wrong Forum!
    Thank you for pointing to the correct forum,
    Feb 2015
    Thank you kindly for that reply underthetire. I appreciate that info even if I'm in the wrong forum... haha
    Sorry for posting in Hass mills!
  1. Door interlock?
    By Edster in forum Fadal
    Last Post: 07-12-2014, 06:40 PM
  2. Door Interlock
    By akhilb in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-16-2011, 10:46 PM
  3. DOOR INTERLOCK
    By gtrrpa in forum Mori Seiki lathes
    Last Post: 04-18-2011, 07:56 PM
  4. Please help-door interlock
    By em322 in forum Okuma
    Last Post: 01-19-2010, 09:54 PM
  5. Door Interlock
    By hatchmar in forum Fanuc
    Last Post: 12-30-2007, 01:52 AM
