586,762 active members*
8,404 visitors online*
    Mar 2009
    10
    YANG ML - 25A
    I have a YANG ML 25A lathe machine with Fanuc O T series.
    Battery went down and it lost all parameters, Parameters have been installed back to the machine but the problem now it cannot read positions for example if I set my zero position (work shift on Z axis) and move Z-40mm, the output or result it only moves -18mm. I changed Parameters from Inches to MM but its still giving me wrong values.
    Secondly the feedrate does not change, it uses constant feedrate which does not correspond to the input feedrate value on the program when using G01. It feeds regardless of the feed override turned off to zero.
    Feb 2015
    10
    Hi MDU,
    How did you put back the parameters? If keying by hand, it should be check again carefully first.
  1. yang 4th axs
    By freemanxxx in forum CNC Machining Centers
    Last Post: 01-19-2016, 10:49 PM
  2. Yang ML-25A
    By Billet Sean in forum Uncategorised MetalWorking Machines
    Last Post: 03-18-2015, 05:48 AM
  3. Yang MV-3A VMC
    By julioykaly in forum G-Code Programing
    Last Post: 07-07-2014, 10:30 AM
  4. yang 4th axs
    By freemanxxx in forum Uncategorised MetalWorking Machines
    Last Post: 04-07-2013, 10:38 PM
  5. yang smv 600
    By eh1203 in forum Fanuc
    Last Post: 04-11-2011, 08:40 AM
