587,006 active members*
3,166 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > Need Help, Tool List Problem
Results 1 to 7 of 7
    Feb 2015
    29
    Hi guys, i need help regarding this:
    (DATA-3/4/2015 - REV.0)
    ( TOOL LIST )
    ( TOOL NAME )
    ( U-Drill D21 TwistDrill 21.00 80.00 1 )
    ( HSS.F D20. EndMill 20.00 100.0 2 )
    ( C.E D16.0 EndMill 16.00 100.0 3 )
    ( Ambore D6 SpotDrill 6.000 100.0 4 )
    ( Burghiu D2.6 TwistDrill 2.600 80.00 5 )
    ( TarodM3 Tap 3.000 50.00 6 )
    i want istead of this (see up) to show me something like this:
    (TOOL LIST)
    (T1=U-DRILL D21)
    ETC
    basically without the aditional info for the tool.....
    Many thanx
    Apr 2008
    47
    Re: Need Help, Tool List Problem
    you can go into the "Tool manager" and rename any tool. or you could "Make a copy" of a tool, and just rename it that way, then remove the "Old" tool from your Tool crib.
    "If everyone is thinking alike somebody's not thinking!"
    HAAS TM-3P and a HAAS OM-2
    Feb 2015
    29
    The thing is that the code is inserting something that i dont want like aditional tool name "TwistDrill, EndMill etc", diameter and so on, and it wont show the Tool Numer in front of tool name....
    Apr 2008
    47
    it won't show the tool number where? in the code after its output? you have to tell it what tool group its from, so it knows where to put it in the library. if you need to change the tool number, go into "Tool mapping" and change the tool number there
    Mar 2006
    31
    You want it to look similar to this?
    O0001
    (126487) (4-30-2015)
    (126487 REV 2) (11:02.4)
    ( ROUND STOCK - INCONEL_718. OD 2 ID 0.9 Z 1.93 )
    ( ROUGH BORE TO .990 - 1.00 )
    ( LENGTH SHOULD BE 1.860 - 1.855 )
    ( T1 = 20S OFFICE ROUGH )
    ( T7 = FIN ISCAR CCMT BORING BAR )
    ( T7 = ISCAR CCMT BORING BAR )
    ( T9 = 15/16 ISCAR DR DRILL )
    N100 ( ROUGH FACE2 )
    G28 U0
    G28 W0
    G00 T0100 (20S OFFICE ROUGH R0.0313)
    G0 X6.0 Z6.0
    M40
    G50 S1000
    G99 G96 S100 M3
    G0 X0.25 Z0.1 M8
    G72 P95 Q105 U0. W0.02 D0.01 F0.004
    Mar 2006
    31
    Obviously I have (tool list) in my post, but I also have this Addin turned on "Add stock tool list and setup sheet.bas". I believe I downloaded that Addin a long time ago. Not sure if its still availible. If you dont understand Addins, heres a link FeatureCAM - Addins - www.featurecam.com
    I can email you the Addin if you cant find it.
    Feb 2015
    29
    Thats exactly what i want from my tool list, you can send me via [email protected], much apreciate
  1. Printing tool list
    By kevinb in forum FeatureCAM CAD/CAM
    Last Post: 07-10-2012, 06:17 AM
  2. TOOL LIST
    By Jking7489 in forum Mastercam
    Last Post: 11-29-2011, 05:58 PM
  3. Standard Tool list
    By cncClintain in forum Mastercam
    Last Post: 06-09-2011, 01:55 PM
  4. Tool list in header
    By MILLMANM in forum Mastercam
    Last Post: 02-13-2010, 04:02 PM
  5. Tool list
    By jeffliu2 in forum GibbsCAM
    Last Post: 11-10-2009, 01:23 PM
