Ok testign Vcarve Pro eval version with out new Tormach.
Plan to buy Vcarve but want to make sure it will work and do what we need...
I have used both of the Vcarve demo flies BullsHead and the restroom sign and can make a nice engraving in VCarve simulation
When I save the tool paths and bring it to the Tormach (Mach3) I only see and get a small partial of the overall item
What you see is what is cut bun not the rest of the code...
I've tried both ARC and ATC ARC in inches
I'm not sure if this is a settings issue in Tormach or VCarve...
Was trying to do a stupid easy 4" x 8" sign test...
New to both the mill and VCarve
I do see a light grey area in the Mach3 Tormach looks like active cut area and larger workpiece dashed line
Any ideas or suggestions?
