586,112 active members*
3,130 visitors online*
    Mar 2015
    6
    Exclamation Chinese 50W Laser Engraving Machine Cutting Problem
    I recently bought this machine from China and it worked perfectly till a while back. There were no problems in engraving and cutting then.
    The software I use is Corel Laser. The problem now is with cutting. When I give the command to cut the material after giving it a specific position, it does not cut at that position. Instead the laser head moves right and up, about 2 inches and starts the process. I thoroughly checked whether there were any changes brought to the settings to cause this problem. It seems to have the same settings as before when it used to cut just right. I have no idea what might be causing this malfunctioning and there are no problems with the position of engraving.
    I am new to all of this, so please kindly assist me in solving this problem.
    Thank you so much in advance.
    Jan 2008
    940
    Re: Chinese 50W Laser Engraving Machine Cutting Problem
    Check your settings in Corel to see if you are starting from origin or from another point.
    Aug 2014
    111
    Nov 2012
    492
    Look and see if theres a box in you laser software called (immediate) make sure its checked.
  1. Buying a laser cutting and engraving machine CHINESE BRANDS
    By KRASI in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-17-2018, 07:57 AM
  2. Chinese Laser not Engraving or Cutting
    By lindari in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-18-2015, 07:45 PM
  3. Chinese Laser Cutting and Engraving Machine TS-6040 60w - Engraving problem
    By Andriette in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-24-2014, 03:44 PM
  4. Problem with my laser engraving cutting machine JZDQ-9060E type
    By almamy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-16-2013, 04:37 AM
  5. Chinese laser engraving/cutting machine
    By we3en in forum Want To Buy...Need help!
    Last Post: 05-05-2011, 01:01 PM
