586,597 active members*
3,398 visitors online*
Results 1 to 17 of 17
    Oct 2013
    84
    Flood coolant nozzle upgrade
    I finally got a chance to upgrade my flood coolant system.. the nozzle area for now. Looking forward to get a larger coolant tank(bin) with a new motor. I bought all the parts from Mcmaster, I could have save more somewhere else but it was convenient. I could have save more $$$ on a plain brass adapter instead of SS hex body adapter.
    Nov 2013
    402
    Re: Flood coolant nozzle upgrade
    WOW! Nice setup.
    Dec 2012
    194
    Yes I agree, nice setup, very clean, looks good.
    Per your quote above what are your thoughts/plans for the tank and pump?
    Jan 2015
    3
    If you don't mind could you post a parts list?
    Jun 2008
    15
    Very nice! Could you share the details?
    Aug 2013
    980
    Great setup with your atc. You won't have to worry about walking away and wondering if you are getting coolant in the right areas
    Oct 2013
    84
    Quote Originally Posted by kbmyers View Post
    I didn't buy all the items at one time, I bought some parts for trial purpose until I finally have a guts to drill and tap the column to mount the manifold. I bought the 3/8 NPT to 1/4 NPT manifold and was hoping to blast the hell out the aluminum... not really until I upgrade the pump. A 1/8 NPT output will probably work better with current coolant pump. The most important item on my list is the manifold and the individual shut off valve, from there you can decide if you really want the longer extension or just install the a flex hose with shut off valve. Don't buy item #2 it will save you $48.66, buy item 3 instead and tighten it up with a small pipe wrench or vise grip. You would only need 2 pcs of the item #12, it comes 10 pcs per box, you can use any screw type I guess as long it's 10-32x 1.625 long.I bought item 4 to mount the 1/4 NPT Loc-Line item #8. Some of my parts are nickel plated brass/aluminum and stainless steel, you can can get a plain simple brass or aluminum to save more $$. By the time I put my kit together I could have done it more simple and cheaper, this what I have and might as well make use of it.
    Attachment 270846
    Oct 2013
    84
    Quote Originally Posted by CadRhino View Post
    Exactly what I need for, I just need a full enclosure now to keep the coolants away from me.
    Oct 2013
    84
    Quote Originally Posted by LRF View Post
    I really like a large bin like some of the guys have use. Someone on eBay was selling an aluminum coolant tank that I'm liking, I was hoping he can extend it out further out of the floor area and mount the pump or upgraded pump out side the coolant cabinet.
    Feb 2006
    7063
    Quote Originally Posted by whagkangmakulet View Post
    No idea whether the pump is adequate or not, but looks to me like your flow is being strangled by the tiny inlet hose feeding that manifold. That will always limit both your flow and pressure. You need that pipe/tube to have a cross-sectional area roughly equal to the combined areas of all the outlets combined.
    Also, flow is as important, if not more important, than pressure. You may well get a better result with larger, lower pressure outlet nozzles, than with smaller, higher-pressure ones. I've always found 1/4" nozzles will always do a much better job clearing chips than 1/8" nozzles.
    Regards,
    Ray L.
    Oct 2013
    84
    Thanks for bringing the up Ray. 5/16 ID hose is currently the largest hose that I can use using the push to connect plumbing. The back of the manifold also has a 3/8 NPT that I'm using for the 3/8 NPT to 5/16 OD hose to connect to the Tormach supplied coupling 1/4? where the factory loc-line hose is connected. Once I upgrade my tank and pump, I will definitely upgrade the inlet hose to maximize the flow. As long as I can direct one of the coolant hose to the tool varied from height and width size of the tool with ATC this will do the job. I'm considering the full enclosure upgrade and the coolant if $$/orders becomes more frequent.
    Mar 2009
    1863
    Nice set up, but you're still locked in with those loc-lines and having to change positions every tome you change tool lengths.
    Here's a picture of what I did to my coolant system. It allows me t keep the coolant on the top of the part with no adjustments.
    Attachment 270860
    Quote Originally Posted by Steve Seebold View Post
    Attachment 270860
    Yep that's how I did mine too. Makes everything much simpler no screwing with coolant lines at tool changes.
    RAD. Yes those are my initials. Idea, design, build, use. It never ends.
    PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
    Nov 2007
    2151
    Quote Originally Posted by R.DesJardin View Post
    And those pesky drilling operations with long tool holder chucks and even longer bits!
    This method would eliminate that problem!
    I like!
    md
    edit: I was wondering about vise also!
    Dec 2012
    194
    Steve, if you don't mind me asking, what is your vise you have in your picture, please?
    Apr 2013
    1788
    Attachment 270860
    Those stainless (?) flexible hoses look nicer and appear to be more rigid than the normal Loc-Line. What is the source?
    Aug 2009
    610
    I am looking at the picture provided about the better solution and I still can't see how that is any different than Loc-Line. It has to be aimed after all- correct? If you are working on anything contoured you would still have to be concerned with trajectory following. I mean good for you guys and if it works keep rolling with it.
  1. Flood Coolant System Upgrade
    By saabaero in forum Tormach Personal CNC Mill
    Last Post: 03-19-2011, 01:10 PM
  2. Coolant nozzle ?
    By 123tool in forum Haas Lathes
    Last Post: 02-17-2010, 06:16 PM
  3. Flexible Coolant nozzle
    By impact in forum Uncategorised MetalWorking Machines
    Last Post: 07-08-2009, 12:02 PM
  4. programmable coolant nozzle
    By jprobst in forum Haas Mills
    Last Post: 06-27-2008, 06:38 PM
  5. Teachable Coolant Nozzle...
    By ProductionPal in forum Videos
    Last Post: 01-09-2008, 09:27 PM
