586,414 active members*
3,188 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Xzero CNC > Raptor > New XZero DIY MACHINE/Test mini raptor
Page 1 of 2 12
Results 1 to 20 of 26
    Oct 2008
    248
    Well I was able to get a machine to test. I'm thinking what I'm looking at will be an amazing little machine. Machine is made from 3/4" aluminum (uprights & end frames) super stiff and rigid with a cutting area of around 12"x12" ballscrews are silky smooth (1610 & 2010) fit and finish is second to none. I will be cutting mostly aluminum, this machine will have no trouble. I haven't set my mind on what spindle to run yet, I hope I will soon.
    Attachment 270718Attachment 270720Attachment 270722
    Oct 2008
    248
    Re: New XZero DIY MACHINE/Test mini raptor
    Wow no replies. I'm surprised
    Aug 2011
    999
    You might get a better response if you had a question or if there would be something for people to contribute. Otherwise it is just another CNC machine. A good looking one for that matter but there would be no point for me to just post "Hey, great machine". Also, since CarveOne has not posted for a while the traffic here has gone way down.
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
    Oct 2008
    248
    YA I can understand that, but on another hand i just figured someone would have said something because it's an amazing machine with lots of potential.
    Jun 2012
    817
    It's a nice little machine that you got to test. The person who designed and built it deserves a pat on the back.
    When you share photos, you rarely get a response unless you are doing a build thread or making something really cool with it..
    Feb 2014
    94
    Coming along quite nicely . Good job .
    35538
    To a lot of people, it's a tiny little toy.
    I've seen a bigger X Zero in person, so a smaller one is nothing special.
    It generally takes something very unique or spectacular to get a lot of comments on photo's alone.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Aug 2006
    87
    It's a cute little thing! I hope you keep us updated as you put it to use.
    May 2008
    4068
    Why make enclosure that high?
    XZero cnc
    Oct 2008
    248
    I made it high so there's lots of head room, I figured if I'm going to make a enclosure I might as well make with a bit of room.
    Quote Originally Posted by gio666 View Post
    Oct 2008
    248
    I've been working on my enclosure, getting closer. Then the chips will fly lol.Click image for larger version.
ID:	275540Click image for larger version.
    Feb 2014
    94
    Quote Originally Posted by mike2768 View Post
    Have you decide what the first item will be when your ready ??
    Oct 2008
    248
    I wish I knew, there's a lot stay tuned.
    Oct 2008
    248
    A little up date, finally almost done the enclosure. It just needs the top and lights.Attachment 277192Attachment 277194Click image for larger version.
    Oct 2008
    248
    Thanks, getting closer
    Oct 2008
    248
    It's alive, still need spindle
    New Cnc router (mini raptor) - YouTube
    Oct 2008
    248
    I've attached a link for YouTube. The video is from my mach3 driver test. The computer I was using has an attitude regarding turning on. So I thought I would try my other PC but the machine would run very choppy and not smooth at all any help would be great. I'm running XP.
    Mach3 driver test - YouTube
    May 2008
    4068
    Choppy and growling sound you had before is from parallel port , Have to check mac address on port or just get uc100 and not have port problem no more
    XZero cnc
    Apr 2015
    93
    Nice Enclosure. What size extrusion did you use for it? Does rock around at all in use? I want to build one for one of my machines.
    Oct 2008
    248
    I used the 1515 (1.5"X1.5") extrusion
Page 1 of 2 12
  1. Build Log: RMGVideos XZero Raptor Build
    By sagreen in forum DIY CNC Router Table Machines
    Last Post: 05-10-2011, 09:00 PM
  2. diy Mini lathe test bed
    By miljnor in forum Vertical Mill, Lathe Project Log
    Last Post: 05-19-2005, 05:44 PM
