586,409 active members*
2,963 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Xzero CNC > Raptor > New XZero DIY MACHINE/Test mini raptor
Results 1 to 20 of 26
    Oct 2008
    248
    Well I was able to get a machine to test. I'm thinking what I'm looking at will be an amazing little machine. Machine is made from 3/4" aluminum (uprights & end frames) super stiff and rigid with a cutting area of around 12"x12" ballscrews are silky smooth (1610 & 2010) fit and finish is second to none. I will be cutting mostly aluminum, this machine will have no trouble. I haven't set my mind on what spindle to run yet, I hope I will soon.
    Attachment 270718Attachment 270720Attachment 270722
    Oct 2008
    248
    Re: New XZero DIY MACHINE/Test mini raptor
    Wow no replies. I'm surprised
    Aug 2011
    999
    You might get a better response if you had a question or if there would be something for people to contribute. Otherwise it is just another CNC machine. A good looking one for that matter but there would be no point for me to just post "Hey, great machine". Also, since CarveOne has not posted for a while the traffic here has gone way down.
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
    Oct 2008
    248
    YA I can understand that, but on another hand i just figured someone would have said something because it's an amazing machine with lots of potential.
    Jun 2012
    817
    It's a nice little machine that you got to test. The person who designed and built it deserves a pat on the back.
    When you share photos, you rarely get a response unless you are doing a build thread or making something really cool with it..
    To a lot of people, it's a tiny little toy.
    I've seen a bigger X Zero in person, so a smaller one is nothing special.
    It generally takes something very unique or spectacular to get a lot of comments on photo's alone.
    Aug 2006
    87
    It's a cute little thing! I hope you keep us updated as you put it to use.
    Jun 2012
    817
    Quote Originally Posted by gio666 View Post
    Ok show me where wooden machine out performs metal machine?
    A well built wooden machine will outperform a poorly built metal one. We see it all the time over here in the DIY section. The material does not make the machine. And I said "rivals" not outperforms.
    We see machines made from aluminum extrusion that are not very rigid sometimes. Most DIY'ers are not engineers so many are lacking in their design, whereas if someone with a strong engineering background builds a wood machine, it can easily rival the extrusion based one.
    May 2008
    4068
    Quote Originally Posted by louieatienza View Post
    I have promoted and defended George's machines for their quality and components. But what you're saying is akin to saying, "I put this IKEA shelf together, so it's DIY." Or. "I attached the basw on my new LED TV, so I have a DIY LED."
    On the other hand, I remember one build where the 1" thick aluminium uprights were cut with a jigsaw, filed, and polished to almost perfection. And no your machine is not a toy, there are so-called mini mills with smaller work areas and less ridgid designs.
    Yes louieatienza has said good thing about my machines, Thanks. But what is the DIY difference from XZero to CNC router parts or fineline machines?
    I think mike was saying, the machines are DIY . They are not set up or running
    XZero cnc
    They're all ready to assemble kits. Most of us consider DIY to be scratch built.
    To be honest, there are probably way too many forums here, and some members always want everything moved to it's own little corner.
    May 2008
    4068
    Yes that true, site so large its hard to know where to post when lots over lap with same info.
    I guess because other kit machine in DIY forum , that's why he posted there.
    XZero cnc
    Apr 2009
    5516
    Fair enough... I do notice the other kit builds from CNCRP and FLA, but then it overlaps with those that buy just the CNCRP trucks and build their machines around that. At least it's not like the one poster that sells plans, then posts stuff like "Watch my machine cut aluminum" with links to his plans in the post LOL!
    Oct 2008
    248
    I've been working on my enclosure, getting closer. Then the chips will fly lol.Click image for larger version.
ID:	275540Click image for larger version.
    Feb 2014
    94
    Quote Originally Posted by mike2768 View Post
    Have you decide what the first item will be when your ready ??
    Oct 2008
    248
    I wish I knew, there's a lot stay tuned.
    Oct 2008
    248
    A little up date, finally almost done the enclosure. It just needs the top and lights.Attachment 277192Attachment 277194Click image for larger version.
    Feb 2014
    94
    Coming along quite nicely . Good job .
    Oct 2008
    248
    Thanks, getting closer
    May 2008
    4068
    Why make enclosure that high?
    XZero cnc
    Oct 2008
    248
    I made it high so there's lots of head room, I figured if I'm going to make a enclosure I might as well make with a bit of room.
  1. Build Log: RMGVideos XZero Raptor Build
    By sagreen in forum DIY CNC Router Table Machines
    Last Post: 05-10-2011, 09:00 PM
  2. diy Mini lathe test bed
    By miljnor in forum Vertical Mill, Lathe Project Log
    Last Post: 05-19-2005, 05:44 PM
