587,035 active members*
2,954 visitors online*
    Feb 2015
    cnc moving in negative cordinates
    Hello, is it normal that a machine moves in native cordinates? When I move the machine forward the DRO's read a negative number instead of positive is there anyway of fixing this so when I move forward its positive? I really apreciate this, thanks.
    May 2012
    22
    Re: cnc moving in negative cordinates
    with MACH3?
    Feb 2011
    212
    I just helped a friend out with his mill .you will need to reverse your setting .
    CONFIG
    Homing /limits
    And look at your x y and z you may have to reverse the settings . Hope this helps
    Feb 2015
    thankyou for your help! i had reversed but does everyone still keep their z axis revered? thankyou so much for the help
    Feb 2011
    212
    No switch it till the axis is reading correctly. Z negative should be going down . Switch hit up if the numbers are getting bigger if you are going down in z
  1. axis not moving Only DRO moving on mach3 screen for cnc router 6040
    By bingaom in forum Charter Oak Automation Support Forum
    Last Post: 09-09-2014, 08:54 AM
  2. Design Options: Moving bridge vs. Moving Cross Beam
    By martin_05 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-22-2014, 08:20 PM
  3. change Fanuc 0-M display cordinates
    By TWM in forum Uncategorised MetalWorking Machines
    Last Post: 11-27-2012, 02:35 AM
  4. No dots in cordinates
    By quasarix in forum Post Processors for MC
    Last Post: 10-30-2010, 07:39 AM
  5. Moving Table vs Moving Gantry; Dremel vs Router
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 03-28-2007, 02:48 AM
