Re: Rotary cut
If you crashed while rotating into the next position, then the solution is simple. Get the tool out of the way while the machine rotates to the next position. One way to do that is to use the machine coordinate system (M92 on my machines) and move to an absolute value in that coordinate system. You can add something like this to the post
*TOOLPATH_CHANGE*
"lnbr" M129 ;TCPM OFF
"lnbr" M25 M27 ;UNLOCK THE TABLE
"lnbr" L Z1. FMAX M92
"lnbr" L X324.Y-595. FMAX M92
"lnbr" ;TOOL #"toolnr" CONTINUES
*END_SECTION*
With this section in your post, the tool will retreat to your "safe position" to avoid any collisions.
There's probably other ways to do it, but this works for us,
Dan
