586,446 active members*
3,615 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Region curve/surface question
    Jan 2015
    13
    I'm having trouble constraining cut to region.
    I select my object. Choose tool. Create box. then...
    Selected a closed region curve which I have created around the outer margin of my object. I assumed that selecting this curve would constrain my subsequent surfacing operations to within the region curve.
    However each time I run simulation it cuts the entire block including outside the region curve.
    I tried raising the curve height to top Z. Then at lowest Z. No joy.
    I tried extruding a surface from the curve and adding a clipping plane at lowest Z. No joy.
    Interestingly using the curve alone actually worked once, but I cannot replicate that result.
    Any ideas?
    Jan 2015
    13
    Re: Region curve/surface question
    disregard! It was a bad curve.
  1. Replies: 1
    Last Post: 09-26-2014, 02:27 AM
  2. 3d toolpath from curve created out of a surface
    By camunderdog in forum Mastercam
    Last Post: 04-28-2013, 01:40 AM
  3. Trimming a curve with a surface
    By dougl in forum BobCad-Cam
    Last Post: 09-07-2012, 09:18 PM
  4. Extrude curve or surface
    By ErnieD in forum BobCad-Cam
    Last Post: 02-18-2012, 02:53 AM
  5. Problems with v23 project curve to surface
    By dnelso in forum BobCad-Cam
    Last Post: 10-05-2009, 06:17 AM
