586,477 active members*
3,395 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > The Design and Construction of a 'Backlash-Free' Rotary Table
Page 6 of 6 456
Results 101 to 106 of 106
  1. #101
    May 2014
    97
    Re: The Design and Construction of a 'Backlash-Free' Rotary Table
    Roger,
    I enjoyed the write up, thx for taking the time. Of particular interest was your 'home brew' metrology device. Very cool.
  2. #102
    Jun 2010
    4256
    Hi Eddard
    Thanks.
    Measurement per se is/was my career.
    Cheers
    Roger
  3. #103
    Jun 2010
    4256
    Someone asked for a photo of the RT in actual use. Herewith.
    Attachment 291298
    Machining a 30 tooth GT2 pulley using a custom fly cutter.
    My own program to make the cutter on the CNC lathe, to the publish specs. Silver steel (drill rod), heat treated.
    My own program to make the pulley. It can be adjusted to cut any number of teeth.
    I want 30 teeth and 90 teeth, with a custom taperlock core for the shaft (also my own design and program).
    The RT works fine, and I believe that the resulting pulley complies with the GT2 specs. A pity the Chinese GT2 (RepRap) belts and pulleys do not seem to comply with the published specs ... The 2 mm pitch is OK, but the tooth profile seems wrong. But I need to do some more measurements to see just where they differ.
    Incidentally, machining a small toothed pulley like this really does require that the TIR on the chuck be very small! This one has been adjusted to be under 25 microns radius. That took some time.
    Cheers
    Roger
  4. #104
    Jun 2010
    4256
    Subsequent research shows that just about every GT2 profile I have seen is different. The published profiles don't match the machined profiles either. There is a separate thread about this.
    In theory Gates owns the GT2 name and you need a licence from them to use it, but some vendors, especially the Chinese, do not seem to have noticed this.
    Cheers
    Roger
  5. #105
    hi, I really like your article
    it's let me learn a lot.
    and this is our website information https://www.teshin.com.tw/en/
    hope u like it.
  6. #106
    Jun 2010
    4256
    Thank you Lillian.
    Cheers
    Roger
Page 6 of 6 456
  1. Backlash free rotary table
    By Zoidberg in forum Linear and Rotary Motion
    Last Post: 03-16-2022, 09:48 PM
  2. Design vs construction body
    By tcs118 in forum Community Club House
    Last Post: 10-31-2013, 08:42 PM
  3. Phase II 4" rotary table backlash.
    By TXFred in forum Benchtop Machines
    Last Post: 02-12-2011, 01:27 AM
  4. Rotary Table Backlash
    By fc911c in forum Uncategorised MetalWorking Machines
    Last Post: 04-18-2010, 10:11 AM
  5. Typical Backlash on a new Yuasa 8" Rotary Table
    By Roy Norris in forum MetalWork Discussion
    Last Post: 08-10-2005, 10:33 AM
