586,102 active members*
2,511 visitors online*
Thread: Open Pocket
    Nov 2005
    244
    Open Pocket
    When machining a open pocket. What is a good and easy way to have the endmill work from the outside of the part and or feature and past.
    Please review .jpg image.
    Thank You
    Jun 2003
    73
    A manual containment boundary is how I would do it. I would make a boundary (geometry from edges or edge loop features) and select the entire solid to machine and contain it within that. If pre-ec11 I would then offset some linework to get a good approach.
    If you have vs 11, then there is some enhanced boundary controls that would work perfect and you wouldn't have to offset any lines for approach.
    Mike W.
    Jun 2003
    73
    I am bad, the new boundary controls aren't available in the roughing cycle. here is an example of doing what you were asking. I would probably rough out the entire part and not jus tthat section but I guess you have your reason.
    Inside the zip file is a ppf in EC 10.75 and an EC PartaModeler file
    Attached Files Attached Files
    Mike W.
