586,443 active members*
3,204 visitors online*
Results 1 to 9 of 9
    Feb 2015
    60w laser need 2 pass at 100% 10mms to cut 2mm acrylic
    Hi.
    I have a 10 months old 60w redsail m500 that i had the same problem since i bought it new . I only cut 2mm acrylic and most of the time cardstock, foam so i didnt bother much. Nowdays im been cutting 4-5mm acrylic and it will take 5-6 passes at 100% power , 10mms speed. I have been adjusting/realign the mirror countless time. im pretty sure i get it pretty close to the center of the mirrors and the cut are straight. but the cutting power remains the same.
    Dec 2012
    19
    The lasers need a good quality and good test before delivery
    Check this out on YouTube!this is our machine
    http://goo.gl/HVpQRI.
    Www.cncmetalcut.com
    Www.laser-solution.com
    Jan 2008
    940
    Re: 60w laser need 2 pass at 100% 10mms to cut 2mm acrylic
    Have you done the slope test for proper focus. I cut 6 mm acrylic at 4 mps with my 60 watt at 85% power using air assist.
    Hi ,my friend .
    what is the length of your tube , and how long did you use it ?
    if you adjust the light path well , i think the problem is the tube, the power is weak .
    please check .
    co2 laser machine&parts. tubes,lens,mirrors,DSP control systems ,powers etc .
    Email/Skype:[email protected]:86-18516298692.
    Feb 2015
    Quote Originally Posted by fixtureman1 View Post
    whats a slope test ?
    Quote Originally Posted by frank wang View Post
    Hi ,my friend .
    please check .
    around 1200mm . for 8 months . how to check is the power is weak ?
    Jan 2008
    940
    You put a piece of acrylic on your bed with one end higher than the other the lower end should be below your normal focal point and the high end above. Draw a line and laser a cut on that line and see where it is the deepest and best cut. That will be your focal point make sure your laser head will clear the high end though.
    Jan 2015
    120
    I cut 5mm acrylic with 50w(not a real only 820mm long) with 2 pass at 90% power.
    Take a look at your mirrors and lens(it may be dirty) it happens to me sometimes...
    Nov 2008
    382
    hi all
    I think the problem is after all the mirrors and lens are clean that the airassist is a must. I cut with a old 40W tube ( over 1.700 hours on it) 6mm acryl with one pass at 85% power and 4 to 5mm speed, but only with air assist not the cone version, a version like epilog from the side . without air assist it would take more then 5 runs and the cut would look ugly not usefull.
    greetings
    waltfl
    Feb 2015
    err. im sorry . i dont really follow. is there any visual illustration for it anywhere ?
    Quote Originally Posted by Mcbride19 View Post
    its the same when its brand new, and even now with cleaned mirrors . still the same.
    Quote Originally Posted by herby08 View Post
    hi all
    greetings
    waltfl
    my machine do has air assist and its on the side.
  1. Need the pass through mirror on the end of the laser?
    By zx10aviator in forum Laser Hardware
    Last Post: 05-06-2014, 07:59 AM
  2. Cutting 1" Acrylic with Multiple Passes and each Pass is Misaligned
    By cryptodecals in forum Glass, Plastic and Stone
    Last Post: 03-05-2014, 01:30 PM
  3. RFQ - Laser Cut Acrylic 14.6 x 15 x 1/2"
    By dshay76 in forum RFQ (Request for Quote)
    Last Post: 12-28-2012, 01:51 PM
  4. Acrylic laser cut
    By Pysiek in forum North America RFQ's
    Last Post: 10-19-2012, 11:17 AM
  5. Replies: 0
    Last Post: 08-15-2011, 03:08 AM
