586,779 active members*
9,210 visitors online*
Page 12 of 12 2101112
Results 221 to 231 of 231
  1. #221
    Aug 2014
    889
    Ok John, what? No updates anymore???
  2. #222
    Jan 2006
    110
    Re: MORE HP for PCNC
    Been very busy designing and fabricating other components for this machine. the TTS tooling cannot use all 5hp so I have a new power drawbar with 3600lb of force and a new modified Hardinge collet, I cut much more aggressively now with TTS but I don't any firm quantitative test results to publish yet, waiting to push the rpm up to 8k.
    Been working towards a highly modified version of PP to accommodate everything I need moving forward.
    I'm putting together a new website dedicated to all the professional upgrades I'll eventually make available as upgrades to greatly enhance the PCNC's commercial production capability. Things that will have a 12 month ROI, more chips faster + more money quicker if you are making some of your living with a PCNC.
    jh
  3. #223
    Jun 2008
    1082
    Don't forget to upload videos! Talk is cheap. :/
  4. #224
    Jan 2006
    110
    that's right, videos cost yours truly way more.
    jh
  5. #225
    Apr 2012
    134
    Can you please post the model and source when you can for:
    Motor
    VFD
    Pulley
    Belt
    You are running on standard 220vAC single phase, right?
    I don't want 5 HP, but maybe they have something in the 2+ HP range. My mill will use a Tormach 770 cartridge, and I'm still trying to decide what motor to use.
    Thanks!
    -Steve
  6. #226
    Sep 2011
    474
    There are brushless AC servos that put any VFD + 3ph motor to shame on a lb per lb basis. This motor weighs about 8 lbs and genertes 3.23kW (4.33hp) of power with a top speed of 4500 rpm. Its about 1/4th the size of the current PCNC 1100 motor:
    Attachment 307062
    Kollmorgen 3 23KW Brushless Servo Motor AKM53K CCCNR 00 Working But Damaged | eBay
  7. #227
    Aug 2015
    368
    Wow, that's bad ass
    Sent from my SM-G900V using Tapatalk
  8. #228
    Sep 2009
    624
    +1
    Steve's right. The 1100 is a well designed, thoughtfully specified machine that lives within a sweet spot for power, speed, and tooling. Like the venerable Chevy 409, it can be stroked and bored, but the base engine is a solid performer. It is becoming -perhaps has already become- a classic of its type.
    I can think of no greater accolade for Greg Jackson.
  9. #229
    Jul 2004
    1424
    Unfortunate that John hasn't been back in the last 10 months to update this thread.
    I would like to see how he has morphed his Tormach since this.
    John?
    Tim
  10. #230
    Oct 2011
    14
    I saw the link on CNCCookBook. I just upgraded pumps. I started to build the ring that popspipes describes but not having an o-ring in the 2" range, I went to the plumbing store nearby on Sunday. The only one close really was a LASCO #95, 1-3/4" ID, 2-1/8" OD, 3/16" thick. I was fighting with it because I didn't have a cutter that would go deep enough and it wouldn't go on even when I was widening the slot. Then, just for grins, I put the O-ring on the spindle by itself. It's hard to describe how well it fits and covers the ID of the seal. Good enough for now and since I had already put some silicone grease on it, I just left it on,
  11. #231
    Feb 2011
    Reviving an old thread beacause the VFD on my 1100 series 3 just died (tr HF07 Watchdog failure fault code) and it seams like a good opportunity to get a more powerful VFD along with the 5hp motor I already have on hand.
  1. New PCNC 770
    By Jblk9695 in forum Tormach Personal CNC Mill
    Last Post: 04-14-2011, 10:53 PM
  2. For those of you with a PCNC 1100
    By HLF Ordnance in forum Tormach Personal CNC Mill
    Last Post: 01-02-2010, 12:51 AM
  3. mastercam and pcnc
    By msn_jrd in forum Tormach Personal CNC Mill
    Last Post: 07-17-2008, 02:19 AM
  4. New to me PCNC 100
    By BSims66173 in forum Tormach Personal CNC Mill
    Last Post: 02-22-2008, 04:32 AM
