I know that what i'm asking is very unusual, but let me try to explain.
I have a cheap chinese laser 50W with 50 x 30 cms cutting area, and it works like a charm for 2 years without any problem, sometimes 8 hours a day for 5 days a week, believe it or not.
One client ask me to cut a piece of 502.6mm wide, so as you image does not cut on the table that cuts only 500mm.
If I can adjust the setup to 503mm x 300mm i will be able to cut this file and keep the client........
I use Laserworks 6.00.44 software and try to change settings to "cheat the machine" in 3 or 4 mm. In the machine there is enough space for it.
In the software there is a page setting that I already did the change, but still not accepting and the machine control panel says "SLOP OVER"
Is there a way to increase this area in 3 or 4mm?
I appreciate any help or idea.
Here is my machine model
Attachment 270308
