Hey guys,
I'm sure this is going to be an easy one. Thanks ahead of time for any help.
I'm using a "hole from dimensions" feature to side mill the ID of a bore. Normally I change the total stock value so the tool doesn't cut air from the center of the bore. This has worked great in the past. However, it seems now I can't change the total stock value. It's locked. I try to change it and it goes right back to it's stuck value, which is too small or too big depending on if I select or deselect Helical ramping.
I'm assuming a setting has changed that I'm overlooking. Changing the stock ID doesn't help.
Any suggestions?
Thanks!
