Hello Folks,
In Camworks it is relatively easy to update a change to an "Open Profile" for example. You simply "edit definition" for that feature then update the tool path. It is not so easy to update a change to a hole location. There is no "edit definition" for a hole on the features side of Camworks. The other day I did something that provided a relatively easy way to update the tool path for a hole location that was changed in the model but I can't remember what I did. Any suggestions how to quickly update the tool path for hole that's been moved would be appreciated.
Harvdog
