586,103 active members*
3,419 visitors online*
    Oct 2006
    10
    Electronically challenged
    I have built a desk top cnc router, I have stepper motors etc., I am looking at controllers, one that looks interesting offers for options an on board g code processor, and an rs-232/rs-485 serial interface, are these desirable options?
    Terry
    Only if the control software your using supports them. Sounds proprietary to me.
    Dec 2005
    439
    Controllers can be built many ways, look at control software; see if there is one you like over others and build around that. ger21 is right some control software can so that but I see the best being ethernet its much faster then RS-232 and simpler to set up. As for the g-code processor that is normaly done on the design side on your desktop and the CNC controller just reads the code
    I'm not lazy..., I'm efficient!
    HAAS GR-408
    Jul 2005
    2415
    The quickest (and least expensive) route is to use what hundreds of other builders use. A PC parallel port(s) to some form of interface card/box driving off-the-shelf stepper driver. The controller software runs on the PC and sends Step & Dir signals for up to 6 axis. The interface unit gives you isolation and buffereing for inputs and outputs and helps with the integration (places to connect the wires).
    For controller software see: www.machsupport.com [MACH3]
    For motor controllers (depending on your motors) see: www.Xylotex.com or
    www.HobbyCNC.com or www.GeckoDrives.com
    You can buy the electronics pretty much done for you. Including power supplies and even complete power supply/motor driver combos.
    Hang around this place and ask questions. Just like the one you did ask. Rs232 or RS485 interface will drop you smack into a proprietary system. You then have fewer options for controller software (usually just theirs) and even fewer sources of help. Pick something hundreds have done and you have a potential of hundreds of ideas and support.
    Tom Caudle
    www.CandCNC.com
    Oct 2006
    10
    Thanks for the replies, they certainly help some one starting out.
    302
    Travel down a paved road rather than a dirt path.
