586,690 active members*
3,054 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Control Software > LaserCut > Need Help!! We've blocked our Laser Controler leetro mpc6525.
    Feb 2015
    We have installed LaserCut 6.0 ( We have used LaserCut 5.3 before ) and after that The Laser System is not initialising anymore, and the laser head is blocked.
    We tried to reinstall LaserCut 5.3 but I think we upgraded the controller with the wrong Firmware or we have installed the wrong driver.
    Can somebodyHelp??
    Thank You!!
    Apr 2006
    108
    Re: Need Help!! We've blocked our Laser Controler leetro mpc6525.
    I would recommend that you try to re-install the firmware. You can find the firmware on the server of RabbitLaserUSA.com web site.. You need to check the section for software and drivers.. then open the link to the directory of software and drivers... then find the firmwares.. then select the appropriate controller or firmware versions.
    here is a direct link.. if cncZone allows it to be posted.
    http://www.rabbitlaserusa.com/Driver...ares/V4.3.0.0/
  1. PLEASE HELP IF YOU CAN!!!!! Leetro MPC6525
    By TheWorkshopGuy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-09-2020, 06:37 AM
  2. CO2 Laser with Leetro 6515 - Software problems
    By crocketman in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-14-2017, 07:16 PM
  3. Convert WK Laser LC1290 leetro to AWC608 - Vic, Aus
    By wolfau in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-25-2014, 12:20 AM
  4. Installing a Leetro mpc6525(6515)" USB controller
    Last Post: 08-08-2013, 04:34 PM
  5. Is there a way to upgrade the memory on a Leetro controler?
    By phylo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-03-2013, 12:38 AM
