In advanced line generating working fields, more and more people would like to choose green line projecting laser alignment in order to obtain high quality line generation in those of working occasions. All of these line generating working fields are requiring high level of accuracy and high precision line measurement on targeting surfaces. As a result, this green laser alignment always adopts import 532nm green laser diode and import glass coated optic lens.
Usually this green line generating alignment laser adopts excellent quality glass coated optic lens. This kind of glass coated cylindrical lens is completely different from plastic optic lens. In both close and long distance line generation working fields, the projecting green reference line is always available with super fineness, high brightness and long distance laser beam visibility. Whatever kind of line generation working fields, this green laser alignment makes uses of the featured advantages of 532nm green laser diode tech.
According to its featured laser beam transverse mode of TEM00, users can always obtain especially light emitting with high level of brightness, super visible positioning and targeting. By mounting it on required machine or machinery with the assistance of mounting bracket, users can just obtain the most precise, accurate line generation on all targeting surfaces with this alignment laser efficiently and successfully.
