Re: How do you mix larger quantities of epoxy granite?
I've been pondering on the same thing.
As soon as you start requiring serious amounts, mixing really becomes an issue.
As voyager points out, if the stuff gets warm, it'l harden quicker.
To me that suggests that you need to mix all the epoxy at once and then quicly mix with the aggregate.If you leave the mixed epoxy in the tub and try to mix it in to aggregate, bit by bit, to get smaller batches to work with, it is likely to cure without getting the chance to be mixed in to the aggregate.
I've thought of making my own mixers, like cement mixers but using buckets, to make small batches very quickly. I think that having all epoxy mixed with the aggregate will slow it down some, especially if you (can) spread it out before adding it to the mold.
For me, the most important thing is to have a quick and fault free workflow, so I can mix many small batches rather than few big ones.
That means good equipment but also a lot of trial and error. And slow epoxy
But I will never attempt to get a massive casting area to vibrate... Way to many risks. I'd use localised vibration, or manual stamping.
Sven
http://www.puresven.com/?q=building-cnc-router
